Rafael Salazar
Rafael Salazar answered on May 28, 2020 1:33 PM
Divya,
Looks like my issue was that I wasn't referencing the dlls correctly like you said since the bin folder was not being copied. I created a new folder, added the dlls there, then referenced the dlls from that new folder instead and it let me publish with no errors. Thank you for your assistance!
Rafael Salazar
Rafael Salazar answered on May 27, 2020 8:33 PM
Divya,
Thanks for answering.
1) I'm not using nuget references so I would assume infragistics doen't need to be in artifacts. Am I supposed to install them a different way on Azure DevOps before I commit?
2) If i remove the references, it throws a bunch of errors on the methods I use infragistics.
