I see. But if I want to get rid of one of the filtering trees, how would I do that?
In your example, if I wanted to get rid of this condition:
const productExpression = {
condition: IgxStringFilteringOperand.instance().condition("contains"),
fieldName: "ProductName",
ignoreCase: true,
searchVal: "Queso"
But keep the second condition only after applying both condititons:
const productExpressions2 = {
ignoreCase: true,
searchVal: "Cabrales"
Would I have to clear all conditions and apply only the ones I want to see?
Yes I have tried that.
In this case when I want to filter out val '1' it would be:
const tree = new FilteringExpressionsTree(FilteringLogic.And);
tree.filteringOperands.push({
fieldName: 'Sort',
condition: IgxNumberFilteringOperand.instance().condition('isNotEqual'),
searchVal: 1
this.grid.advancedFilteringExpressionsTree = tree;
So now we should get:
sort |
column1 |
column2 |
2 |
2 |
3 |
3 |
And then when I want to filter out value '2' as well as value 1 at the same time it would be:
this.grid.advancedFilteringExpressionsTree.filteringOperands.push({
fieldName: 'Sort',
searchVal: 2
Which should result in:
sort |
column1 |
column2 |
3 |
3 |
Is this the correct implementation?
