I would like to know if I right-clicked on the cell header. How do I do this?
My current code:
Private Sub ugCommission_MouseUp(sender As Object, e As System.Windows.Forms.MouseEventArgs) Handles ugCommission.MouseUp Dim cmItemNum As New ContextMenuStrip Dim cmCommDue As New ContextMenuStrip If e.Button = Windows.Forms.MouseButtons.Right Then Dim ptCurrent As Point = New Point(e.X, e.Y) Dim uiElement As Infragistics.Win.UIElement = CType(sender, UltraGrid).DisplayLayout.UIElement.ElementFromPoint(ptCurrent) Dim ugCell As UltraGridCell = uiElement.GetContext(GetType(UltraGridCell)) Dim ugRow As UltraGridRow = uiElement.GetContext(GetType(UltraGridRow)) ' Thought ugUIElement would be it, but it is also nothing when I right click on the col header cell
Dim ugUIElement As UltraGridUIElement = uiElement.GetContext(GetType(UltraGridUIElement)) If ugCell IsNot Nothing Then ugCommission.Selected.Rows.Clear() ugRow.Selected = True If ugCell.Column.Key = "ITEM_NUM" Then _cmItemNum.Show(ugCommission, ptCurrent) ElseIf ugCell.Column.Key = "COMM_DUE" Then _cmCommDue.Show(ugCommission, ptCurrent) End If End If End If End Sub
