Cannot perform ‘Like’ operation on System.Double and System.String.
New DiscussionHave a webcombo using a SqlDataSource (in the *.aspx – not using InitializeDataSource or binding from C#)
ComboTypeAhead=”Suggest”
DataValueField=”Version”
The stored procedure used by the webcombo returns Version with data type = FLOAT
When I type something in the webcombo, it does not filter based on the typed value.
Then when I click a button. I get the error (details below – please advise)
Exception Details: System.Data.EvaluateException: Cannot perform ‘Like’ operation on System.Double and System.String.
Source Error:
Stack Trace:
[EvaluateException: Cannot perform ‘Like’ operation on System.Double and System.String.]
System.Data.BinaryNode.SetTypeMismatchError(Int32 op, Type left, Type right) +21
System.Data.LikeNode.Eval(DataRow row, DataRowVersion version) +451
System.Data.DataExpression.Invoke(DataRow row, DataRowVersion version) +81
System.Data.Index.AcceptRecord(Int32 record, IFilter filter) +103
System.Data.Index.InitRecords(IFilter filter) +214
System.Data.Index..ctor(DataTable table, Int32[] ndexDesc, IndexField[] indexFields, Comparison`1 comparison, DataViewRowState recordStates, IFilter rowFilter) +414
System.Data.DataTable.GetIndex(IndexField[] indexDesc, DataViewRowState recordStates, IFilter rowFilter) +240
System.Data.DataView.UpdateIndex(Boolean force, Boolean fireEvent) +165
System.Data.DataView.UpdateIndex(Boolean force) +12
System.Data.DataView.SetIndex2(String newSort, DataViewRowState newRowStates, IFilter newRowFilter, Boolean fireEvent) +113
System.Data.DataView.SetIndex(String newSort, DataViewRowState newRowStates, IFilter newRowFilter) +17
System.Data.DataView.set_RowFilter(String value) +170
Infragistics.WebUI.UltraWebGrid.DBBinding.ProcessDataViewForFillRows(DataView dataView, RowsCollection rows) +570
Infragistics.WebUI.UltraWebGrid.DBBinding.FillRows(UltraWebGrid grid, RowsCollection rows, IEnumerable datasource) +303
Infragistics.WebUI.UltraWebGrid.DBBinding.BindList(IEnumerable datasource) +3012
Infragistics.WebUI.UltraWebGrid.DBBinding.DataBind(Object dataSource, String dataMember) +2050
Infragistics.WebUI.UltraWebGrid.UltraWebGrid.DataSourceViewSelectCallBack(IEnumerable dataSource) +131
System.Web.UI.DataSourceView.Select(DataSourceSelectArguments arguments, DataSourceViewSelectCallback callback) +31
Infragistics.WebUI.UltraWebGrid.UltraWebGrid.DataBind() +1429
Infragistics.WebUI.UltraWebGrid.UltraWebGrid.LoadPostData(String postDataKey, NameValueCollection values) +5515
System.Web.UI.Page.ProcessPostData(NameValueCollection postData, Boolean fBeforeLoad) +693
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1743
Version Information: Microsoft .NET Framework Version:2.0.50727.3082; ASP.NET Version:2.0.50727.3082
