The string parameter 'key' cannot be null or empty. Parameter name: key
New DiscussionI’ve attached a sample project, inside the zip file is an overview.txt file that explains what we are trying to do in more detail.
How to reproduce:
If you start running the application and immediately click the search button – you see a postback and the results in the textboxes are displayed in the status textbox below:
But if you start the application and click around with the navigation controls (or select different rows on the grid) and then click on the search button – you get the following exception that appears to be coming from the grid control:
The string parameter ‘key’ cannot be null or empty.
Parameter name: key
Exception Details: System.ArgumentException: The string parameter ‘key’ cannot be null or empty.
Parameter name: key
Source Error:
| An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. |
Stack Trace:
[ArgumentException: The string parameter ‘key’ cannot be null or empty. Parameter name: key] System.Web.UI.StateBag.get_Item(String key) +8820932 Infragistics.Web.UI.Framework.Data.DataRecord.GetValue(String fieldName) +87 Infragistics.Web.UI.GridControls.ControlDataRecord.GetValue(ControlDataField field) +240 Infragistics.Web.UI.GridControls.ControlDataItemCollection.GetValue(Int32 index) +207 Infragistics.Web.UI.GridControls.ControlDataItemCollection.GetValue(ControlDataItem item) +71 Infragistics.Web.UI.GridControls.ControlDataItem.get_Value() +47 Infragistics.Web.UI.GridControls.GridRecordItem.GetTextNode() +154 Infragistics.Web.UI.GridControls.ControlDataItem.Infragistics.Web.UI.GridControls.IXPathDataNavigableObject.get_Xml() +156 Infragistics.Web.UI.GridControls.XPathDataNavigable.GetNextSibling() +43 Infragistics.Web.UI.GridControls.XPathDataNavigator.MoveToNext() +87 Infragistics.Web.UI.GridControls.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) +329 Infragistics.Web.UI.GridControls.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) +318 Infragistics.Web.UI.GridControls.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) +318 Infragistics.Web.UI.GridControls.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) +318 Infragistics.Web.UI.GridControls.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) +318 Infragistics.Web.UI.GridControls.XPathDataNavigator.get_OuterXml() +199 Infragistics.Web.UI.GridControls.GridRenderer.RenderContents(HtmlTextWriter writer) +1251 |
