Infragistics Community Forum / Web / Ignite UI for jQuery / infragistics.lob.js:289 Uncaught TypeError: Cannot read property 'fields' of undefined
Adam Kelley
Adam Kelley asked on Jan 14, 2016 9:18 AM
Just above line 289 reads:
* Infragistics.Web.ClientUI Hierarchical Grid 15.2.20152.1027
* Copyright (c) 2011-2015 Infragistics Inc.
* http://es.infragistics.com/
* Depends on:
* jquery-1.4.4.js
* jquery.ui.core.js
* jquery.ui.widget.js
* infragistics.dataSource.js
* infragistics.ui.shared.js
* infragistics.util.js
* infragistics.ui.grid.framework.js
Would missing these cause the JS error?
I’m currently using the following:
<!-- JavaScript Library Dependencies -->
<script src="http://ajax.aspnetcdn.com/ajax/modernizr/modernizr-2.8.3.js"></script>
<script src="http://code.jquery.com/jquery-1.9.1.min.js"></script>
<script src="http://code.jquery.com/ui/1.10.3/jquery-ui.min.js"></script>
<!-- Ignite UI Required Combined JavaScript Files -->
<script src="http://cdn-na.infragistics.com/igniteui/2015.2/latest/js/infragistics.core.js"></script>
<script src="http://cdn-na.infragistics.com/igniteui/2015.2/latest/js/infragistics.dv.js"></script>
 <script src="http://cdn-na.infragistics.com/igniteui/2015.2/latest/js/infragistics.lob.js"></script>
    Vasya Kacheshmarova
    Vasya Kacheshmarova answered on Jan 14, 2016 9:18 AM
    Hello Adam,
    The names of the JavaScript files containing the combined scripts for all of IgniteUI are as follows:
    – infragistics.core.js :  shared dependencies(required)
    – infragistics.lob.js :  a line-of-business controls
    – Infragistics.dv.js : all data visualization controls
    Along with these files also the css for the IgniteUI controls should be loaded. Css files are as follows:
     Ignite UI Required Combined CSS Files -->
        <link href="http://cdn-na.infragistics.com/igniteui/2015.2/latest/css/themes/infragistics/infragistics.theme.css" rel="stylesheet" />
        <link href="http://cdn-na.infragistics.com/igniteui/2015.2/latest/css/structure/infragistics.css" rel="stylesheet" />
    Also the jQuery and jQuery ui scripts should be loaded. The final list of the scripts should look as following:
    <!-- Ignite UI Required Combined CSS Files -->
    You can also refer to our online samples browser where you can find working samples with script references for different controls.
    For further reference of Ignite UI scripts I believe you will find the following articles from our documentation useful:
    JavaScript Files in Ignite UI
    Infragistics Content Delivery (CDN) Network for Ignite UI
    I hope you find this information helpful.
    Please do not hesitate to contact me if you have any additional questions regarding this matter.
Adam Kelley
10 years, 8 months ago
Feb 25, 2026 9:43 AM
