Infragistics Community Forum / Web / Ignite UI for React / Uncaught TypeError: Cannot read properties of null (reading 'contentType')
Igor B.
Igor B. asked on Feb 23, 2022 4:39 PM
I’m trying to load files into this library via ExcelUtility.load(file), where `file` is an xlsx file.
The application crashes and the following error occurs:
CachedLoadPackagePart.ts:39 Uncaught TypeError: Cannot read properties of null (reading 'contentType')
    at CachedLoadPackagePart.get (CachedLoadPackagePart.ts:39:1)
    at Async_ForEachHelper$1.e (AlternateContentChoice_combined.ts:810:1)
    at Async_ForEachHelper$1.b (Async_combined.ts:239:1)
    at ret (type.ts:1645:1)
    at Function.Async.h (Async_combined.ts:50:1)
    at Async_ForEachHelper$1.a (Async_combined.ts:202:1)
    at Function.Async.d (Async_combined.ts:32:1)
    at AlternateContentChoice_combined.ts:796:1
    at ObjectModelExcelDocumentManager.OfficeDocumentManager._q (AlternateContentChoice_combined.ts:790:1)
    at ObjectModelExcelDocumentManager.OfficeDocumentManager._p (AlternateContentChoice_combined.ts:759:1)
    at Async_ForEachHelper$1.e (AlternateContentChoice_combined.ts:816:1)
    at ObjectModelExcelDocumentManager.OfficeDocumentManager._o (AlternateContentChoice_combined.ts:574:1)
    at ObjectModelExcelDocumentManager._o (WorkbookLoadManagerExcel2007_combined.js:922:1)
    at WorkItem_WorkItemAsync.ae (AlternateContentChoice_combined.ts:530:1)
    at WorkItem_WorkItemAsync.p (WorkItem_combined.ts:250:1)
    at WorkItem_WorkItemAsync.WorkItem.w (WorkItem_combined.ts:64:1)
    at WorkItemScheduler_TimeSlicedImpl.d (WorkItem_combined.ts:355:1)
    at WorkItem_combined.ts:359:1
File examples:
file1: https://docs.google.com/spreadsheets/d/1mxH2il1fg4JYRS1HChVD50M_i6B0Cuic/edit?usp=sharing&ouid=114306164329761920916&rtpof=true&sd=true
file2: https://docs.google.com/spreadsheets/d/1UheBWCzp-po1SBvjh6PCNRu8HMiJEkmR/edit?usp=sharing&ouid=114306164329761920916&rtpof=true&sd=true
    Andrew Goldenbaum
    Andrew Goldenbaum answered on Feb 23, 2022 4:39 PM
    Hello Igor,
    I have been investigating into the behavior you are seeing, and I have reproduced it. I believe this could be related to the spreadsheet being created in Google Docs. I am basing this impression on the fact that I have recreated the second Excel workbook in Microsoft Excel, and it loads correctly.
    This behavior is unexpected, and as such I have asked our engineering teams to examine it further. To ensure it receives attention, I have logged it in our internal tracking systems with a development ID of 273834. I have also created you a private support case that I will be linking to this issue so you can be notified when a fix or other resolution becomes available. It has an ID of C-00222538, and you can access it after signing into your account on the Infragistics website, here: https://account.infragistics.com/support-cases. You can continue to send updates to this thread or the private support case at any time.
Igor B.
4 years, 5 months ago
Feb 25, 2026 10:31 AM
