Infragistics Community Forum / General / BC30560: 'WebScriptManager' is ambiguous in the namespace 'Infragistics.Web.UI'.
Michael
Michael asked on Nov 13, 2012 4:14 PM
I’m using 2012.2 on ASP.NET v4.5 on a Win2k8 R2 box.  I used to use 2012.1.  I have run the Version Utility on my project and the site.  However, I’m still getting this.
I have uninstalled 2012.1 and reinstalled 2012.2 with no improvement.
Is there any other information you need to help me determine the problem.  I’m a long-time programmer but I’m a newb to object oriented and .NET.
    Rob Hudson
    Rob Hudson answered on Nov 8, 2012 7:58 PM
    I am just another user, so my answer isn't authoritative
    Three things I would check…
    1)  Check that you don't have the version 12.1 dll's in the bin folder
    2)  Check that you don't have references to both assembly versions in your web.config file
    3)  Check that you don't have a reference to the 12.1 assembly at the top of your page
      Michael
      Michael answered on Nov 8, 2012 8:22 PM
      1. The only Infragistics DLL in my or the server's bin is the 12.2 version.
      2. Here's the web.config section with the references:
            <assemblies>
              <add assembly="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
              <add assembly="System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
              <add assembly="Infragistics4.Web.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"/>
              <add assembly="Infragistics4.WebUI.Documents.Reports.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"/>
              <add assembly="Infragistics4.WebUI.Documents.Excel.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"/>
              <add assembly="Infragistics4.WebUI.Documents.Word.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"/>
              <add assembly="Infragistics4.WebUI.Documents.IO.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"/>
              <add assembly="Infragistics4.WebUI.Documents.Core.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"/>
              <add assembly="Infragistics45.Web.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
              <add assembly="Infragistics45.WebUI.Documents.Reports.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
              <add assembly="Infragistics45.WebUI.Documents.Excel.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
              <add assembly="Infragistics45.WebUI.Documents.Word.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
              <add assembly="Infragistics45.WebUI.Documents.IO.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
            </assemblies>
          </compilation>
      3. Here's what is at the top of my Site.Master page:
      <%@ Register Assembly="Infragistics4.Web.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.ListControls" TagPrefix="ig" %>
      <%@ Register Assembly="Infragistics4.Web.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.LayoutControls" TagPrefix="ig" %>
      The detailed compile looks like this:
      c:\windows\system32\inetsrv> "C:\Windows\Microsoft.NET\Framework64\v4.0.30319\vbc.exe" /t:library /utf8output /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Configuration\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System\v4.0_4.0.0.0__b77a5c561934e089\System.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\14e3493f\00987ead_e586cd01\DotNetOpenAuth.OAuth.Consumer.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Microsoft.CSharp\v4.0_4.0.0.0__b03f5f7f11d50a3a\Microsoft.CSharp.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\a32a663d\8020f0a6_e586cd01\Microsoft.ScriptManager.MSAjax.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Xml\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\13d8778c\80f3bea5_e586cd01\System.Web.Providers.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_64\System.EnterpriseServices\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics4.WebUI.Documents.Reports.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics4.WebUI.Documents.Reports.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics45.Web.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics45.Web.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Data.DataSetExtensions\v4.0_4.0.0.0__b77a5c561934e089\System.Data.DataSetExtensions.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\5e7c0e06\008a57a6_e586cd01\System.Web.Optimization.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.ComponentModel.DataAnnotations\v4.0_4.0.0.0__31bf3856ad364e35\System.ComponentModel.DataAnnotations.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_64\System.Data\v4.0_4.0.0.0__b77a5c561934e089\System.Data.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics45.WebUI.Documents.Excel.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics45.WebUI.Documents.Excel.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.WorkflowServices\v4.0_4.0.0.0__31bf3856ad364e35\System.WorkflowServices.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics45.WebUI.Documents.Word.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics45.WebUI.Documents.Word.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Web.Entity\v4.0_4.0.0.0__b77a5c561934e089\System.Web.Entity.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics4.WebUI.Documents.Excel.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics4.WebUI.Documents.Excel.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Core\v4.0_4.0.0.0__b77a5c561934e089\System.Core.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Web.DynamicData\v4.0_4.0.0.0__31bf3856ad364e35\System.Web.DynamicData.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_64\System.Web\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Web.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Drawing\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\3f73673b\008a57a6_e586cd01\AspNet.ScriptManager.jQuery.UI.Combined.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\f64c35d8\8001e6ac_e586cd01\DotNetOpenAuth.Core.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\c9fbd719\80f3bea5_e586cd01\Antlr3.Runtime.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.ServiceModel.Activation\v4.0_4.0.0.0__31bf3856ad364e35\System.ServiceModel.Activation.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.ServiceModel.Activities\v4.0_4.0.0.0__31bf3856ad364e35\System.ServiceModel.Activities.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\App_global.asax.8b2k–5e.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\85a098b7\8020f0a6_e586cd01\Microsoft.ScriptManager.WebForms.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.IdentityModel\v4.0_4.0.0.0__b77a5c561934e089\System.IdentityModel.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\a6e49b4b\00987ead_e586cd01\DotNetOpenAuth.AspNet.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\6d95e1fd\8001e6ac_e586cd01\DotNetOpenAuth.OAuth.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics4.WebUI.Documents.IO.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics4.WebUI.Documents.IO.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics45.WebUI.Documents.Reports.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics45.WebUI.Documents.Reports.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics4.WebUI.Documents.Core.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics4.WebUI.Documents.Core.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics4.WebUI.Documents.Word.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics4.WebUI.Documents.Word.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Activities\v4.0_4.0.0.0__31bf3856ad364e35\System.Activities.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\d4178a80\00c5afae_e586cd01\Microsoft.AspNet.Membership.OpenAuth.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Xml.Linq\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.Linq.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\b995934b\008a57a6_e586cd01\AspNet.ScriptManager.jQuery.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Web.Services\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Web.Services.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Web.ApplicationServices\v4.0_4.0.0.0__31bf3856ad364e35\System.Web.ApplicationServices.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\aa6b5db7\96c9c956_eebdcd01\ITS.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Design\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Design.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Web.Extensions\v4.0_4.0.0.0__31bf3856ad364e35\System.Web.Extensions.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics45.WebUI.Documents.IO.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics45.WebUI.Documents.IO.v12.2.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\505ef7dd\00987ead_e586cd01\DotNetOpenAuth.OpenId.RelyingParty.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\bace8d7c\00987ead_e586cd01\DotNetOpenAuth.OpenId.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.ServiceModel\v4.0_4.0.0.0__b77a5c561934e089\System.ServiceModel.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Runtime.Serialization\v4.0_4.0.0.0__b77a5c561934e089\System.Runtime.Serialization.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Infragistics4.Web.v12.2\v4.0_12.2.20122.1007__7dd5c3163f2cd0cb\Infragistics4.Web.v12.2.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.ServiceModel.Web\v4.0_4.0.0.0__31bf3856ad364e35\System.ServiceModel.Web.dll" /R:"C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Windows.Forms\v4.0_4.0.0.0__b77a5c561934e089\System.Windows.Forms.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\96408140\80f3bea5_e586cd01\WebGrease.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\6654c881\00b788a7_e586cd01\Microsoft.Web.Infrastructure.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\b0b05ffa\802e17ae_e586cd01\EntityFramework.dll" /R:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\assembly\dl3\fbcda224\00e95f97_9c7ccd01\Microsoft.AspNet.Web.Optimization.WebForms.dll" /out:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\App_Web_nwxuitma.dll" /D:DEBUG=1 /debug+ /win32resource:"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\nwxuitma.res" /nowarn:41008,40000,40008 /define:_MYTYPE=\"Web\" /imports:Microsoft.VisualBasic,System,System.Collections,System.Collections.Generic,System.Collections.Specialized,System.ComponentModel.DataAnnotations,System.Configuration,System.Linq,System.Text,System.Text.RegularExpressions,System.Web,System.Web.Caching,System.Web.DynamicData,System.Web.SessionState,System.Web.Security,System.Web.Profile,System.Web.UI,System.Web.UI.WebControls,System.Web.UI.WebControls.WebParts,System.Web.UI.HtmlControls,System.Xml.Linq,System.Web.Optimization /warnaserror- /optionInfer+  "C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\App_Web_nwxuitma.0.vb" "C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\App_Web_nwxuitma.1.vb"
      Microsoft (R) Visual Basic Compiler version 11.0.50709.17929
      Copyright (c) Microsoft Corporation.  All rights reserved.
      C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\App_Web_nwxuitma.0.vb(787) : error BC30560: 'WebScriptManager' is ambiguous in the namespace 'Infragistics.Web.UI'.
              Private Function __BuildControlWebScriptManager1() As Global.Infragistics.Web.UI.WebScriptManager
      C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\App_Web_nwxuitma.0.vb(788) : error BC30560: 'WebScriptManager' is ambiguous in the namespace 'Infragistics.Web.UI'.
                  Dim __ctrl As Global.Infragistics.Web.UI.WebScriptManager
      C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\e22c2559\92c7e946\App_Web_nwxuitma.0.vb(1265) : error BC30560: 'WebScriptManager' is ambiguous in the namespace 'Infragistics.Web.UI'.
                  Dim __ctrl2 As Global.Infragistics.Web.UI.WebScriptManager
      C:\inetpub\wwwroot\Site.Master(26) : error BC30560: 'WebScriptManager' is ambiguous in the namespace 'Infragistics.Web.UI'.
                  __ctrl = New Global.Infragistics.Web.UI.WebScriptManager()
        Rob Hudson
        Rob Hudson answered on Nov 8, 2012 9:29 PM
        You mentioned the master page…
        Are there Register Assembly directives at the top of the child page?
        Michael
        Michael answered on Nov 8, 2012 9:34 PM
        Unfortunately, there aren't any directives at the top of the default.aspx that uses Site.Master.
        [Infragistics] Petar Ivanov
        [Infragistics] Petar Ivanov answered on Nov 9, 2012 8:18 AM
        Hello Mcase,
        Looking at the list of referenced assemblies from your web.config, it seems that both 4and 4.5Infragistics assemblies are being referenced, for instance:
        All assembly references including in the web.config and in the page/master page directives should point to one CLR version of the assemblies.
        Please let me know if this helps.
        Michael
        Michael answered on Nov 12, 2012 2:00 PM
        When I saw your reply, I thought for sure that would do it.  It didn't.  Here's the web.config now:
            <compilation strict="false" explicit="true" targetFramework="4.5" debug="true">
              <assemblies>
              </assemblies>
            </compilation>
        I checked the file on the development server and it's identical.  I also rebooted the development server (different reason) so IIS is reset.
        Any other thoughts?
        [Infragistics] Petar Ivanov answered on Nov 13, 2012 10:43 AM
        Hello mcase,
        Thank you for your reply.
        Can you confirm that the Master page directives also point to the 4.5 assemblies ?
        "3. Here's what is at the top of my Site.Master page:
        <%@ Register Assembly="Infragistics4.Web.v12.2, Version=12.2.20122.1007, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.LayoutControls" TagPrefix="ig" %>"
        Michael
        Michael answered on Nov 13, 2012 4:08 PM
        Thanks.  I had taken the Infragistics4 references out but they re-appeared.  When I removed them again, the ASP.NET page is working.
        Thanks for everyone's help!  You're all the best.
        [Infragistics] Petar Ivanov answered on Nov 13, 2012 4:14 PM
        Hi mcase,
        Thanks for your reply. I'm glad that the issue is resolved.
        Please feel free to contact me if any additional questions regarding this matter arise.
Michael
13 years, 8 months ago
Feb 25, 2026 9:44 AM
