Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / get/set values of WebDatePicker client-side
Tom
Tom asked on Jan 6, 2013 12:08 PM
I am using a WebDialogWindow to provide a modal dialog box for editing the contents of a WebDataGrid. I’m having some trouble getting and setting the value of a WebDatePicker in that modal dialog.
<script language=”javascript”>
var currentRow;
function gridTemplateOpening(sender, args)
var dialog = $find(‘<%= cnModalDialog.ClientID %>’);
currentRow = args.get_row();
var dateText = currentRow.get_cellByColumnKey(“expire_datetime”).get_text();
$get(“<%=cnTextBox.ClientID%>”).value = dateText;
$get(“<%=cnWebDatePicker.ClientID%>”).value = dateText;
dialog.set_windowState($IG.DialogWindowState.Normal);
</script>
In this example cnTextBox is an asp:TextBox control. This control displays the date from column “expire_datetime” just fine. The cnWebDatePicker (a WebDatePicker control) however shows no selected value when the dialog opens. Does it not have a .value property or is that not the correct way to set it’s value? Better yet, can you direct me to the CSOM documentation for the WebDatePicker control? I have not been succesful finding it.
My environment is 2010.vol 2 CLR 2.0
    [Infragistics] Viktor Snezhko
    [Infragistics] Viktor Snezhko answered on Jul 29, 2010 8:49 PM
    The WebDatePicker is javascript based control. Any operation with getting setting values, should be done through javascript member methods/variables. To set value the following can be used:
    var dp = $find("<%=cnWebDatePicker.ClientID%>");
    if(!dp)
       return;
    // to set value of datepicker, you need Date object, so you may try
    var date = new Date(dateText);
    dp.set_value(date);
    // you also may try to use set_text(str),
    // however, format of dateText should match with format of datePicker.
    dp.set_text(dateText);
    To get value, you may use something like
    alert(‘value=’ + $find(“<%=cnWebDatePicker.ClientID%>”).get_value());
      jay
      jay answered on Aug 20, 2010 6:40 PM
      I tried to create a client side javascript function that will set default values for my Start and End date fields which are WebDatePicker controls. I only want to set them once.  If the user changes that then then it is being saved in pagestate.
      I expanded from your example but can not seem to get this to work.
      Setting the new date value for dpDtEnd to today’s date – 1 yr. and
      then doing an alert below return the value 20.
      dtToday.getDate(): 5
      Setting the new date value for dpDtEnd to today’s date – 1 yr. and then doing an alert below return the value 5. dtTodayMinusOneYear.getDate(): 5
      Am I using the correct event?
      <td>
          <ig:WebDatePicker ID="dpDateStart" runat="server" EnableWeekNumbers="true" ClientSideEvents-Initialize="SetSearchDatesDefault"
          ChangeMonthToDateClicked="true" EnableMonthDropDown="True" EnableYearDropDown="True" >
              <ClientSideEvents CalendarClosed="set_str_date" />
          </ig:WebDatePicker>
          <ig:WebDatePicker ID="dpDateStart_old" runat="server" Visible="false" />
      </td>
      <td>
          and
      </td>
      <td>
          <ig:WebDatePicker ID="dpDateEnd" runat="server" EnableWeekNumbers="true" ClientSideEvents-Initialize="SetSearchDatesDefault"
      ChangeMonthToDateClicked="true" EnableMonthDropDown="True" EnableYearDropDown="True">
             <ClientSideEvents CalendarClosed="set_end_date" />
         </ig:WebDatePicker>
         <ig:WebDatePicker ID="dpDateEnd_old" runat="server" OnValueChanged="dpDateStart_ValueChanged" Visible="false" />
      </td>
      function SetSearchDatesDefault() {
          alert('SetSearchDatesDefault Begin');
          var dpDtStart = $find("<%=dpDateStart.ClientID%>");
          alert('dpDateStart: ' + $find("<%=dpDateStart.ClientID%>").get_value());
          var dpDtEnd = $find("<%=dpDateEnd.ClientID%>");
          alert('dpDateEnd: ' + $find("<%=dpDateEnd.ClientID%>").get_value());
          var dtToday = new Date();
          alert('dtToday.getDate(): ' + dtToday.getDate());
          var dtTodayMinusOneYear = new Date(dtToday.getYear()-365, dtToday.getMonth(), dtToday.getDay());
          alert('dtTodayMinusOneYear.getDate(): ' + dtTodayMinusOneYear.getDate());
          dpDtStart.set_value(dtTodayMinusOneYear.getDate());
          dtDtEnd.set_value(dtToday.setDate());
          return;
          alert('SetSearchDatesDefault End');
      </script>
      Thanks!
        [Infragistics] Viktor Snezhko answered on Aug 23, 2010 4:40 PM
        I looked at your codes, they looked confusing to me.
        I think that Date.get/setFullYear should be used instead of get/setYear. Why to subscract 365 years if you need to substract only 1 year. Also, the set_value expects Date object, but not integer returned Date.getDate(), which is actually day of month.
        It is easier to use 1st param (sender) instead of $find(…).
        Below I wrote a sample for you, which intitializes one editor to today date and another editor to today-1year.
        function initDP1(sender, evtArgs)
         var date = new Date();
         sender.set_value(date);
        function initDP2(sender, evtArgs)
         date.setFullYear(date.getFullYear() - 1);
        </script>
        <ig:WebDatePicker ID="WebDatePicker1" runat="server">
          <ClientSideEvents Initialize="initDP1" />
        </ig:WebDatePicker>
        <ig:WebDatePicker ID="WebDatePicker2" runat="server">
          <ClientSideEvents Initialize="initDP2" />
        </ig:WebDatePicker>
      Bouabdellah Hafid
      Bouabdellah Hafid answered on Sep 14, 2010 2:54 PM
      Please, could you explain me how to send a value (date) from a textBox to webdatepicker?
        [Infragistics] Viktor Snezhko answered on Sep 14, 2010 5:24 PM
        I assume that you ask how to set value to datepicker on client. Because on server it should be obvious: take Text property of TextBox, convert it to DateTime and set Value property of WebDatePicker. On client you may use set_value() method or set_text(). The set_value(Date) is most reliable, because set_text(string) depends on format and may fail. Below are 2 examples for both cases:
        function setText()
         var input = $get('<%=TextBox1.ClientID%>');
         var dp = $find('<%=WebDatePicker1.ClientID%>');
        // dp.set_value(input.value);
         dp.set_text(input.value);
        function setDate()
         var input = $get('<%=TextBox2.ClientID%>');
         var fields = input.value.split('-');
         if(fields.length != 3)
          return;
         var date = new Date(parseInt(fields[0], 10), parseInt(fields[1] - 1, 10), parseInt(fields[2], 10));
         dp.set_value(date);
        </script>
        <ig:WebDatePicker ID="WebDatePicker1" runat="server"></ig:WebDatePicker>
        <asp:TextBox ID="TextBox1" runat="server" Text="01/03/2010"></asp:TextBox>
        <asp:TextBox ID="TextBox2" runat="server" Text="2009-8-20"></asp:TextBox>
        <input type="button" value="Set text from 1" onclick="setText()" />
        <input type="button" value="Set date from 2" onclick="setDate()" />
        jay
        jay answered on Oct 4, 2010 3:45 PM
        Thanks so much Viktor that corrected the problem!
        Subhash Sharma
        Subhash Sharma answered on Oct 31, 2012 3:04 PM
        Hi I am using WebDateChooser , I want to clear the control when i click the button on client click using javascript.
        Please reply needfull.
        [Infragistics] Viktor Snezhko answered on Oct 31, 2012 4:12 PM
        Hi Bubhash,
        In case of WebDateChooser, you may use global igdrp_getComboById or ig$ methods to get reference to webdatechooser object, and use get/setValue methods to get/set value of WebDateChooser. Below are examples:
        <igsch:WebDateChooser ID="WebDateChooser1" runat="server"></igsch:WebDateChooser>
        <input type="button" value="clear" onclick="igdrp_getComboById('WebDateChooser1').setValue(null)" />
        <input type="button" value="get" onclick="alert('value:' + ig$('WebDateChooser1').getValue())" />
        <input type="button" value="set" onclick="ig$('WebDateChooser1').setValue(new Date(1955, 1, 19))" />
        Subhash Sharma
        Subhash Sharma answered on Nov 1, 2012 8:40 AM
        Thanks for your reply.Thank u again …..
        Done.
Tom
13 years, 4 months ago
Tom
Feb 23, 2026 8:30 PM
