Infragistics Community Forum / Desktop / Ultimate UI for Windows Forms / Programmatically select next row in an UtraGrid
Andre
Andre asked on Apr 17, 2017 6:35 PM
I’m trying to select the next row in an UtraGrid from outside the control.
So I have created a class MyUltraGrid derived from the original UltraGrid and added the following method
public void SelectNextRow()
if (this.ActiveRow == null)
return;
var nextIndex = this.ActiveRow.Index + 1;
if (nextIndex < this.Rows.Count)
this.Selected.Rows.Clear();
this.Rows[nextIndex].Selected = true;
this.Rows[nextIndex].Activated = true;
This works well. But it doesn´t work if I use a GroupByRow.
Can anyone give me a hint how to achieve the “select next row” functionality in a GroupByRow scenario?
I would like to achieve the same behavior which happens if I hit key up / down right inside the UltraGrid.
greetings
Andre
    Mike Saltzman answered on Apr 17, 2017 6:35 PM
    Hi Andre,
    There's a much easier way. Any time you want to simulate keyboard actions with the grid, you can simply use the PerformAction method:
    this.PerformAction(UltraGridAction.BelowRow);
Andre
9 years, 3 months ago
Feb 19, 2026 9:10 PM
