Infragistics Community Forum / Desktop / Ultimate UI for Windows Forms / Attaching Dataset to Ultragrid with Multiple Tables
Bill Strough
Bill Strough asked on Apr 15, 2020 6:05 AM
I have a dataset that contains three tables – A, B1, B2. A stands by itself. B1 and B2 have a relationship. I have two grids on my form – A and B.
Grid A’s datasource = Dataset.A and I am not having any issues with the data showing in the grid. Grid B’s datasource should be tables B1 and B2. Grid B, however is where I am having a problem. I have tried setting grid B’s datasource = Dataset.B and Dataset (by itself).
After setting the datasource for grid B I loop through the bands to hide any tables that are not B1 or B2, which happens to be table A. Once done nothing shows in grid B.
Is there a way to do this with all three tables in the same dataset? The dataset was created as an .xsd file.
Thanks!
    Teodosia Hristodorova
    Teodosia Hristodorova answered on Apr 13, 2020 11:59 AM
    I have been looking into your requirement and created a small sample in order to demonstrate how such behavior could be achieved. For the purposes of the example I created DataSet with three tables (each one has a unique name) and as you described the first one stands by itself and there is a relation between the other two.
    After setting both grids’ DataSource property to this DataSet, my suggestion in order to achieve your requirement is to set the DataMember property of each grid to the name of the table you need. Keep in mind that the DataMember property of the grid that contains the tables with a relationship has to be set to the parent table.
    public Form1()
               InitializeComponent();
               DataSet _data = getData();
               this.ultraGrid1.DataSource = _data;
               this.ultraGrid1.DataMember = "table0Name";
               this.ultraGrid2.DataSource = _data;
               this.ultraGrid2.DataMember = "table1Name";
           private DataSet getData()
               DataTable table0 = new DataTable("table0Name");
             //Add columns and rows
               DataTable table1 = new DataTable("table1Name");
               DataTable table2 = new DataTable("table2Name");
               DataSet set = new DataSet("dataSetName");
              //Add tables to the DataSet, create and add the relation between table1 and table2
               return set;
    Attached you will find my sample for your reference. Please test it on your side and let me know how it behaves. If this is not an accurate demonstration of what you are trying to achieve please feel free to modify it and send it back to me along with steps to reproduce. Alternatively, if the behavior cannot be replicated please feel free to provide your own sample. Remove any external dependencies and code that is not directly related to the issue, zip your application and attach it in this case.
    3755.UltraGrid_DataSet
      Bill Strough
      Bill Strough answered on Apr 14, 2020 4:25 PM
      That worked PERFECTLY!! Thanks so much Teodosia. I spent so much time on this and was afraid I would need to either create two difference datasets or two instances of the same database but remove the unneeded table(s). This is a way better solution.
        Teodosia Hristodorova answered on Apr 15, 2020 6:05 AM
Bill Strough
6 years, 4 months ago
Feb 25, 2026 7:48 AM
