Infragistics Community Forum / Desktop / Ultimate UI for Windows Forms / UltraDateTimeEditor defaults to a date and time(some cases) value when clicked on the header controls in the dropdown area when the winforms application is launched from citrix.
Toji Mathew
Toji Mathew asked on Dec 9, 2015 8:05 PM
The UltraDateTimeEditor usually don’t set a value to the editor when the header controls on the dropdown area are cicked.
But when the application is launched from citrix, the editor is set with date, when the header controls are clicked.
I have not added any events to the UltraDateTimeEditor control.
Am not sure whether this is a Citrix problem or Infragistics problem.
This issue only happens when the application is launched from citrix.
(Picture is attached showing where I clicked on the header control and what value is appearing on the editor.)
Thank you.
    Michael DiFilippo
    Michael DiFilippo answered on Dec 2, 2015 7:47 PM
    Hello Toji,
    Thank you for following up. I've researched this in a non-citrix environment and our DateTimeEditor's textbox portion updates the date when navigating with the arrow buttons. But as you've described once you click the header, the arrow buttons or the header won't update the year as you navigate outwards and to another date.
    It appears Citrix is honoring the behavior of the regular inbox DateTimPicker. In other words Citrix appears to be behaving normal, but outside the only way to update the date is actually clicking on the date or changing the month. Do you require the textbox to update as you enter the header portion as you change the view?
      Toji Mathew
      Toji Mathew answered on Dec 2, 2015 8:47 PM
      The UltraDateTimeEditor ver is infragistics4 v13.2 for winforms.
      My .net framework version is 4.5
      In non-citrix environment everything is working normal.
      But in citrix environment, when I click on the next/back arrow or on the month text in the middle of the dropdown header, then only the date is getting updated in the textbox portion of the UltraDateTimeEditor.
      Usually in non citrix environment, the texbox portion won't update in like that in the above case.
        Michael DiFilippo
        Michael DiFilippo answered on Dec 3, 2015 3:23 PM
        Hello Toji,
        We can't prevent Citrix from updating the textbox portion of our control. It should behave like this, as does with the Microsoft's DatePicker control. We can fix the control when it's not being used by Citrix to update the textbox when the end user is either viewing the month or year portion of the calendar. Is this something you would be interested in? This would in affect make the control behave the same whether or not it's running on Citrix. I am currently in an active discussion with my team on figuring out whether or not this is a development issue. I'll keep you posted, but let us know if you have any additional questions.
        Toji Mathew
        Toji Mathew answered on Dec 3, 2015 4:34 PM
        The Previous/Next button on the dropdown works normal on both Infragistics UltraDateTimeEditor and Microsofts DateTimePicker controls when opened from citrix or without citrix.
        But the problem looks like on the "month, year" text seen on the header portion on the dropdown, on Infragistics UltraDateTimeEditor.
        Note: "month, year" I mean is the control area with text displayed as "December, 2015", between the Previous and Next arrow, on the screen shot attached on my initial post.
        Microsoft's DateTimePicker don't change the date or time part when clicking on the "month, year" text seen on the header portion of the dropdown with citrix or without citrix.
        But Infagistic's UltraDateTimeEditor changes the date and time part when clicking on the "month, year" text seen on the header portion on the dropdown with citrix. This issue is seen when opening via citrix only.
        For UltraDateTimeEditor, the mask I have set is "{date} hh:mm:ss", which shows the time part in 24hrs format.
        For DateTimePicker, the CustomFormat property I have set is "dd/MM/yyyy HH:mm:ss", which shows the time part in 24hrs format and I have set the Format property to "Custom".
        Thank you.
        Michael DiFilippo
        Michael DiFilippo answered on Dec 3, 2015 11:09 PM
        Hello Toji,
        Thank you for clarifying the behavior in the environments you tested in but this makes it all that more difficult to resolve since the calendar portion is Microsoft's control. It's highly possible that Citrix once behaved that way with the DatePicker and Microsoft fixed that. But knowing that we use their MonthCalendar control we can't make a change like that. I couldn't even find events that are triggered when clicking the text. I was trying to find a way to clear the textbox without any luck.
        Toji Mathew
        Toji Mathew answered on Dec 4, 2015 3:09 PM
        I assume Infragistic's was using Microsoft's "Month Calendar" control in Infragistic's UltrDateTimeEditor control.
        What verion on Microsoft's "Month Calendar" control was Infragistics using?
        If Microsoft has fixed the issue, can infragistics Update the UltraDateTimeEditor to use the latest microsoft's calendar or
        tell me how can I replace the UltraDateTimeEditor's calender portion with Microsoft's calendar?
        Thank you.
    Toji Mathew
    Toji Mathew answered on Dec 9, 2015 7:15 PM
    Still the primary issue exists even in the attached example.
    Mike Saltzman answered on Dec 9, 2015 8:05 PM
    Hi Toji,
    Mike has been discussing this issue with me and I thought I'd try to clear up what's happening here.
    I assume by "the primary issue" you mean that if you run Mike's Sample and drop down the first control (which is an UltraMaskedEditor) and then click on the Month or header buttons, the date changes. If I understand correctly, this is what you do NOT want to happen. But this is what's happening when your application runs over Citrix. Correct?
    Just to be clear, the issue in this case, is that Mike's sample is not using the UltraDateTimeEditor. He's created a simulated DateTimeEditor using the Masked Editor and the Microsoft MonthCalendar control and he is changing the text portion of the masked editor any time the DateChanged event of the MonthCalendar fires – which it does when you click on the header.
    The UltraDateTimeEditor control actually uses the Microsoft MonthCalendar and internally, it responds to the DateChanged event of the MonthCalendar to update it's text portion. However, it also has some code to trap MouseDown and detect when the user clicks on the header and in this case it deliberately does NOT update the text (date) when you click on the header.
    So clearly what's happening here is that when you run your application on Citrix, something is going wrong with this process. Either Citrix is not sending the mouse messages to the control in the exactly the same order, or there is some kind of timing or focus issue which is preventing the UltraDateTimeEditor from properly detecting that you clicked on the header. So it ends up changing the text when it should not.
    There's really not much we can do about this, as we don't have any control over the messages Citrix is sending to the control.
    My recommendation would be to use UltraCalendarCombo instead of UltraDateTimeEditor. The UltraCalendarCombo doesn't rely on any of the Microsoft controls and thus it's not likely to have the same kinds of issues.
Toji Mathew
10 years, 10 months ago
Dec 9, 2015 8:05 PM
Feb 20, 2026 1:04 PM
