Infragistics Community Forum / Test Automation For Micro Focus Uft Windows Forms / How to get the visible data from a particular cell in SwfTable object
Lakshmi
Lakshmi asked on Jul 16, 2009 1:05 PM
Hi
When I was using GetCellData method, iam retrieving the data like “1617.0792315” from a cell.
But the displayed(visible) value is rounded to 2 decimals and showing as “1617.08”. To do some validations at any cost i need to retrieve only the visible value from all cells in a table.
To achieve this, which method i supposed to use in QTP?
Any help is highly appreciated.
Regards
Lakshmi
    Alan Halama
    Alan Halama answered on Jun 8, 2009 7:35 PM
    Lakshmi,
    You can use either the GetCellProperty or GetNAProperty methods to get the Text of the cell.  For example, both of the following could be used:
    msgbox SwfWindow("WinEditors Within WinGrid").SwfTable("ultraGrid1").GetCellProperty("1","0;Item","Text")
    Note that the second parameter for GetCellProperty is the column and requires the band before the column, this is why "0;" is passed in as part of the column string.
    For GetNAProperty, you may want the to read my post on Where to get a list of all properties I can view using GetNAProperty?
    Let me know if you have any questions with this matter
    Alan
      Lakshmi
      Lakshmi answered on Jun 8, 2009 7:49 PM
      Hi Alan
      GetCellProperty is working as per my requirement. Before posting the query I tried with GetCellProperty("1","0;Item","Value"). But it is also getting the complete hidden value. that's why posted.
      Thanks alot for the help.
      Regards
      Lakshmi
        Abdul
        Abdul answered on Jul 16, 2009 1:05 PM
        Use dotnet spy and try to find where the required data is stored and script it like
        For k= 0 to …….SwfTable("ultraGrid1").Object.Datasource.Column.count-1
        If …….SwfTable("ultraGrid1").Object.Datasource.Column.Item(k).ColumnName="0;Item' Then
         ColumnIndex=k
        End If
        obj=…….SwfTable("ultraGrid1").Object.Datasource.Row(RowNo).Array
        required text=obj(ColumnIndex)
        Let me know if it doesnot work.
        Fawaz
Lakshmi
17 years, 1 month ago
Feb 20, 2026 12:24 PM
