Setting Active Tab on Page load
New DiscussionI have a Set of tabs(5 total), each tab has a listview on it. Control works fine when switching tabs and loading data. The problem arrises when I try to change the selected tab when the user first request the page and has a value in the request url. Example MYPage.aspx?t=3, so the page defaults to tab 3 instead of the first tab. The error the pops up is the listview on the tab doesn’t exist
The error I get says it can’t find the listview control on the page…
Error Message
IPageableItemContainer ‘listview3’ not found.
Description: An unhandled exception occurred during the execution of the current web request. Exception Details: System.InvalidOperationException: IPageableItemContainer ‘listview3’ not found.
Sample Code in page_init
If Not Request.Item(“t”) Is Nothing Then
If IsNumeric(Request.Item(“t”)) Then
WebTab1.SelectedIndex = CInt(Request.Item(“t”))
End If
Else
WebTab1.SelectedIndex = 0
End If
Strip down sample of webtab, I have removed the tabs/control in tab since the code is huge.
HTML/Control
<ig:WebTab ID=”WebTab1″ runat=”server” Height=”550px” Width=”100%” onselectedindexchanged=”WebTab1_SelectedIndexChanged” StyleSetName=”Default”>
<tabs>
</tabs>
<PostBackOptions EnableLoadOnDemandUrl=”true” EnableLoadOnDemand=”true” EnableReloadingUnselectedTab=”true” EnableAjax =”true”/>
<AutoPostBackFlags SelectedIndexChanged =”On”/>
</ig:WebTab>
I am hoping I am just setting the active tab wrong, or at the wrong time, or there is something else I am missing.
