So here is my test project. On the button I have:
WebHierarchicalDataGrid1.Behaviors.Paging.PageIndex = 2;
I would have thought this would work but… Any suggestions?
using System;
using System.Linq;
using System.Web;
using System.Web.UI;
using Infragistics.Web.UI.GridControls;
using TotalCare.Enterprise.Common.ZeroClient;
namespace TotalCare.Enterprise.ZeroClient.RequestFacility.secure.Manager.Request
public class Parent
public Parent()
Description_l = string.Empty;
Id_l = 0;
public Parent(int id, string desc)
Description_l = desc;
Id_l = id;
private string Description_l;
public string Description
get { return Description_l; }
set { Description_l = value; }
private int Id_l;
public int ID
get { return Id_l; }
set { Id_l = value; }
public partial class _TestForm : TotalCare.Enterprise.ZeroClient.RequestFacility.common.tctBaseForm
protected override void OnInit(EventArgs e)
if (DesignMode)
return;
base.OnInit(e);
if (Session["Test"] == null)
Session["Test"] = CreateData();
WebHierarchicalDataGrid1.DataSource = Session["Test"];
if (Page.IsPostBack == false)
WebHierarchicalDataGrid1.DataBind();
public List<Parent> CreateData()
List<Parent> xx = new List<Parent>();
for (int x = 0;
x < 90;
x++)
Parent curParent = new Parent(x, "Desc" + Convert.ToString(x));
xx.Add(curParent);
return xx;
protected void Button1_Click1(object sender, EventArgs e)
<body>
<form id="theForm" runat="server">
<asp:ScriptManager ID="ScriptManager2" EnablePartialRendering="true" runat="server">
</asp:ScriptManager>
<asp:Button ID="Button1" runat="server" OnClick="Button1_Click1" Text="Button" />
<ig:WebHierarchicalDataGrid ID="WebHierarchicalDataGrid1" runat="server" AutoGenerateBands="false"
AutoGenerateColumns="False" DataKeyFields="ID" Width="300px" Height="350px" InitialDataBindDepth="0"
InitialExpandDepth="0">
<Columns>
<ig:BoundDataField DataFieldName="ID" Width="120px" Key="ID">
<Header Text="id_parent" />
</ig:BoundDataField>
<ig:BoundDataField DataFieldName="Description" Width="120px" Key="Description">
<Header Text="desc_parent" />
</Columns>
<Behaviors>
<ig:Paging PagerAppearance="Bottom" QuickPages="5" PageSize="15" Enabled="true">
</ig:Paging>
</Behaviors>
</ig:WebHierarchicalDataGrid>
</form>
</body>
