Hi Brian,
Unfortunately no, you need to use the version of TestAdvantage with an identical Major and Minor assembly version number, and CLR. So in your case you would need to use TestAdvantage 7.3 since you are using NetAdvantage 7.3.
GetNAProperties is only really an exploratory method to help learn more about the property names and their data types. It’s useful for testers who may have limited access to their developers and want more information on the fly. If you do have access to your developer it should be easier to ask them what that datatype is and what properties it has.
If for some reason that is not a viable option for you, there are other methods. Albeit they will require a greater amount of understanding of code. You could use .NET Reflector, have it open your application, then find the data type that you are looking for.
According to your previous entry in the forums, you would need to expand the references of your application, right click on the reference to Framework, and select Go To Assembly. Find that assembly, which hopefully should be either in the directory of your application or it’s bin directory. If you find that assembly, then you can search for it via F3 or View-> Search to search for “Summit.Framework.View.DDItem”, double click it in the search window to highlight it in the main window. Finally right click it and select dissemble. It should open a Disassembler window.
Use the information that you garner from that to access the data via GetNAProperty. Note that GetNAProperty returns allows you to dig down through public properties. It will only return values of properties for simple datatypes such as string, int, double, datetime, etc.
As I stated this is a much more advanced method of trying to learn about a particular object, and is why we created GetNAProperties, but as this is not a window open to you, due to versioning restrictions, and if the developer is not available to you, it is at least an additional option.
