Infragistics Community Forum / Web / Ignite UI for jQuery / Making a row editable dynamically
Singh
Singh asked on Feb 13, 2018 4:09 PM
I have 3 bands in igHierarchicalGrid. I have few columns which are editable in the second band.
I am using the default row level editing with Done and Cancel buttons. After SaveChanges is called on the Done button click I want to refresh the grid, expand it and make one of the cells in a row to be editable dynamically.
I am calling
grid.igHierarchicalGrid("dataBind"); which refreshes the grid but I am not able to edit the row without again clicking on it.
I want to make a row editable dynamically which has a particular ID as primary key just after the grid is refreshed and expanded.
I am able to refresh and expand the grid.
I have tried using StartEdit but it needs endEdit which I don't want to call:
gridUpdating.startEdit(row.Id, "Comment");
Can you please suggest something?
Regards
Singh
    Singh
    Singh answered on Jan 3, 2018 8:07 PM
    In addition to the above issue:
    My grids are load on demand. As per the requirements, when I refresh the grid I need to append a custom text to one of the cells in the column.
    It refreshes the grid with the custom value, now if the user clicks the row manually to make it editable ( because I am not able to make it editable dynamically), the Done button remains disabled unless a value is changed in the that row. I want Done button to be enabled so that it can go into save changes.
    Regards
    Singh
      Singh
      Singh answered on Feb 5, 2018 11:15 AM
      Can anyone please reply to this?
      Regards
      Singh
    Vasil Pavlov
    Vasil Pavlov answered on Jan 5, 2018 4:24 PM
    Hello, Singh
    If the startEdit method requires endEdit, there is a chance you are incorrectly targeting the parent grid instead of the child one and because the editing hasn’t finished, it throws an error.
    When you expand your child grid, the “expand” method has a callback function which you may use to edit the rows programmatically. Here’s how do to it:
    • Inside the callback use the “allChildren” method to get a flat list of all child grid elements
    • After that – jQuery’s eq() method to reduce the list to a single object.
    • Then call “startEdit” with the ID of the row you want to edit.
    I made a small sample, check it out.
    Vasil Pavlov
    HierarchicalGrid
      Singh
      Singh answered on Jan 29, 2018 4:07 PM
      hi,
      I tried the above but I get the following error:
      "Editing the specified row or column is currently not possible. It should be in view on the current page and virtualization frame.
      My code is as below:
      $(document).delegate("#igGrid", "iggriddatarendered", function (evt, ui) {
       if (expandAll === true) {
      var parentGrid = $("#igGrid").igHierarchicalGrid("rootWidget");
      var domElement = parentGrid.rowById(rowID);
      if (domElement != null) {
      $("#igGrid").igHierarchicalGrid("expand", domElement, function () {
      //updating the first row of the first child table
      var children = $("#igGrid").igHierarchicalGrid("allChildren");
      children.eq(0).igGridUpdating("startEdit", currentTradeIdFileTypeId);
        Singh
        Regards
        Singh
        Vasil Pavlov
        Vasil Pavlov answered on Feb 5, 2018 4:44 PM
        Hello Singh,
        This error message gets thrown when the igGrid control couldn’t find the row or column you are trying to edit – usually when it doesn’t exist in the browser’s DOM because of the virtualization or paging.
        How do you initialize the “currentTradeIdFileTypeId” variable that you are using in the “startEdit” method? If you haven’t set it properly, it might be the cause of the issue.
        Vasil Pavlov
        Singh
        Singh answered on Feb 7, 2018 3:30 PM
        Hi Vasil,
        I have checked what you suggested but currentTradeIdFileTypeId always has the correct value. It is set somewhere above in the code. Can you please suggest something else?
        Regards
        Singh
        Vasil Pavlov
        Vasil Pavlov answered on Feb 13, 2018 4:09 PM
        Hello Singh,
        There could be some other thing in the code that is causing the issue and which I am missing, but it is not possible to know without the whole grid configuration and the event handlers that you are using.
        Is there a way for you to provide me with an isolated code sample? Or modify the sample I sent you with your settings and event handlers and send it back to me?
        Vasil Pavlov
Singh
8 years, 6 months ago
