Cannot declare 'IgxTimeXAxisComponent' in an NgModule as it's not a part of the current compilation.
New DiscussionI’m trying to modify the sample project found here:
https://es.infragistics.com/community/forums/f/ignite-ui-for-angular/122841/igx-pie-chart-igx-line-chart/540293#540293
testsampleLine.zip
I’ve taken the line chart and I’m converting the igx-category-x-axis to an igx-time-x-axis. This works fine, but then I’m trying to package the chart up as a component and display it via an IgxNavigationDrawer. If I leave it as a category-x-axis there’s no problem, but as soon as I change it to an igx-time-x-axis (and include IgxTimeXAxisComponent in the declarations section of my app.module.ts) then I get this error in my ng serve console:
Cannot declare ‘IgxTimeXAxisComponent’ in an NgModule as it’s not a part of the current compilation.
and in the browser console I get
core.js:4009 Uncaught Error: Angular JIT compilation failed: ‘@angular/compiler’ not loaded!
I have attached minimal sample where you should be able to reproduce the problem. The sample works as-is, but if you uncomment line 28 of app.module.ts you will see the error:
