Infragistics Community Forum / Web / Ignite UI for Angular / Is there any way to change text color of igx-grid-cell based on text
Ashish  Mishra
Ashish Mishra asked on Jan 4, 2021 12:18 PM
I am using ignite ui for the first time in angular. I am facing some problem. Basically I have created library for ignite ui grid and consuming it. I want to make particular grid cell text color change based on text which i am passing in my grid columns like this( in 2nd object using property textColorChange and textColor)
            field: 'ProductName',
            resizable: true,
            sortable: true,
            filterable: true,
            isTooltip: true,
            isHtml: true,
            field: 'QuantityPerUnit',
            filterable: true,
            sortable: true,
            columnWidth: '200px',
            textColorChange: true,
            textColor: [{text: 'Success', color: 'green'},{text: 'Failure', color: 'red'}]
            resizable: true,
            sortable: true,
            filterable: true,
            isTooltip: true,
            isHtml: true,
            filterable: true,
            sortable: true,
above object states that in column QuantityPerUnit if I found Success keyword then change the text color to green, same for Failure keyword also or any keyword.
This is I tried:
html
  <igx-column
         #col
         *ngFor="let column of columns"
         [field]="column.field"
         [header]="column.title ? column.title : column.field"
         [dataType]="column.dataType ? column.dataType : 'string'"
         width="{{ column.columnWidth ? column.columnWidth : config.defaultColumnWidth }}"
         [cellClasses]="column.textColorChange ? textColorChangeClasses: ''"
ts
private successTextColorCondition(rowData: any, columnKey: any): boolean {
    return rowData[columnKey] === this.columns.forEach((text) => {
      text.textColor['text']
  private failureTextColorCondition(rowData: any, columnKey: any): boolean{
    return rowData[columnKey] === 'Failure'
  textColorChangeClasses = {
    successText: this.successTextColorCondition
.scss
.successText {
   color: $success-text-color
But I am getting error core.js:4352 ERROR TypeError: Cannot read property 'columns' of undefined
Is this correct way to do it? or is there any other way to achieve this.
I took help of this stackblitz https://stackblitz.com/github/IgniteUI/igniteui-live-editing-samples/tree/master/angular-demos/grid/grid-cell-styling
    Monika Kirkova
    Monika Kirkova answered on Jan 4, 2021 12:18 PM
    Hello Ashish,
    After investigating this further, I determined that your requirement could be achieved by checking whether the cell value of some column equals the text from the textColor property of that column:
    private successCondition = (rowData: any, columnKey: any): boolean => {
      var text1;
      this.columns.forEach((column) => {
        if(column.field == columnKey){
          text1 = column.textColor[0].text;
          console.log(column.textColor[0].text)
            return rowData[columnKey] ==  text1;
    Additionally the definition of the columns could look as follows:
    <igx-column *ngFor="let col of columns" [field]="col.field"
             [header]="col.title ? col.title : col.field" [cellClasses]="col.textColorChange ? beatsPerMinuteClasses: ''"></igx-column>
    I have prepared a sample, demonstrating the described behavior. Please test it on your side and let me know if you need any further information regarding this matter.
    Monika Kirkova,
Ashish Mishra
5 years, 9 months ago
Feb 20, 2026 11:11 AM
