Infragistics Community Forum / Web / Ignite UI for Angular / How to add "Select All" selection for Igx ComboBox
Afif Halim
Afif Halim asked on Feb 22, 2022 7:16 AM
Is there a way to add the “Select All” button to the IgxCombo selection?
For example, adding below of the search input
Any help will be highly appreciated.
Thanks.
Afif
    Viktor Kombov
    Viktor Kombov answered on Feb 21, 2022 5:37 PM
    Hello Afif,
    Thank you for posting in our community.
    What I can suggest for achieving your requirement is using the Header template of igxCombo where you can add your custom content:
    HTML:
    Select All
    TYPESCRIPT:
    export class ComboSelectAllButtonComponent {
      @ViewChild('combo') public combo!: IgxComboComponent;
      public onSelectAllClick() {
        if (this.combo.selection.length === this.combo.data?.length) {
          this.combo.deselectAllItems();
        } else {
          this.combo.selectAllItems();
    Attached you will find a small sample where is demonstrated how the suggested approach is working.
    Please test the sample on your side and let me know whether you find it helpful.
    Viktor Kombov
    IgxComboSelectAllCheckBox.zip
      Afif Halim
      Afif Halim answered on Feb 22, 2022 2:54 AM
      Hi Viktor,
      Thanks for your wonderful solution, I'm able to implement the changes successfully.
      However, one note from my end, I'm using this.combo.selectedItems() instead of this.combo.selection to make it works, probably because I'm using the older version (v11).
      Thanks!
      Afif
        Viktor Kombov
        Viktor Kombov answered on Feb 22, 2022 7:16 AM
        Hello Afif,
        I am glad that you find this suggestion helpful!
        Regards
        Viktor Kombov
Afif Halim
4 years, 7 months ago
Feb 24, 2026 9:57 AM
