Infragistics Community Forum / Web / Ignite UI for jQuery / Prevent Negative Numbers in a numeric textbox
Guru Srini
Guru Srini asked on May 17, 2018 5:53 AM
I have an igGrid with edit mode dialog. On it, I have a textbox which accepts only numbers. I’m trying to prevent negative numbers from being entered in this field. I tried the below:
settings.ColumnSetting().ColumnKey("test").DefaultValue(0).Required(true).NumericEditorOptions(opt=> {
opt.ValidatorOptions(vopt =>
 vopt.ValueRange(0);
When i run with above and after I enter a correct value, as soon as textbox loses focus, I get an error on infragistics.lob.js.
Unable to get property ‘toString’ of undefined or null reference
Please help.
Guru
    Vasya Kacheshmarova
    Vasya Kacheshmarova answered on May 15, 2018 10:37 AM
    Hello Guru,
    I crated a small sample where I set the valueRange option of numeric editor. On my side everything worked as expected and when a value less than 0 is entered and the editor looses focus validation message appears. Once the value, within the range, is entered the cell value is correctly set without any exception thrown. For my sample I am using latest 18.1 version which is 18.1.152. I tested this under Chrome, Firefox and Edge browser.
      Guru Srini
      Guru Srini answered on May 17, 2018 3:18 AM
      Thanks Vasya:) I removed the validator and added the below option. Seems to work.
      opt.DataMode(NumbericEditorDataMode.UInt);
      Guru
        Vasya Kacheshmarova
        Vasya Kacheshmarova answered on May 17, 2018 5:53 AM
        Hello Guru,
        I am glad that you managed to achieve your requirement.
Guru Srini
8 years, 3 months ago
Feb 23, 2026 8:54 AM
