TypeError: Cannot read property 'document' of null
New DiscussionI get the error: TypeError: Cannot read property ‘document’ of null on Infragistics.lob.js:880
Steps to recreate:
1: Hit script link which executes previewHTMLContent function (append the html to htmlEditor div).
2: Hit edit button which executes loadHTMLEditor function. This clears the content/styles/css of the htmlEditor div then loads the HTML editor with the content html.
3: Change the script by clicking on a new script link and the previewHTMLContent function is executed again with the new HTML
4: Hit edit button for new script. This is where the div empties out and the javascript error occurs.
Once you load the HTMLEditor, are you unable to reload it?
HTML:
<div>
<div class="col-md-4">
<div class="panel panel-default">
<div class="panel-heading">
<button class="btn btn-info pull-right" type="button"><span class="glyphicon glyphicon-plus"></span> Add</button>
<h3>Script Documents</h3>
<div class="clearfix"></div>
</div>
<div class="panel-body">
<ul class="nav nav-pills">
@foreach (var script in @Model)
<li>
<span class="glyphicon glyphicon-arrow-right pull-right"></span>
<a href="BLOCKED SCRIPTvoid(0);" class="btn btn-default btn-script" data-id="@script.ID">@script.Name</a>
</li>
</ul>
</div>
</div>
</div>
<div class="col-md-8">
<button id="Edit" class="btn btn-info pull-right" type="button" data-id=""><span class="glyphicon glyphicon-pencil"></span> Edit</button>
<h3>Details</h3>
</div>
<div id="container">
<div id="htmlEditor"></div>
</div>
</div>
</div>
</div>
</div>
Javascipt:
$(function () {
$('a.btn-script').click(function () {
var id = $(this).data('id');
$.ajax({
url: "/Scripts/Display/",
type: "POST",
data: { id: id},
success: function (result) {
clearContent();
previewHTMLContent(result.script);
setEditDataId(id);
$('#Edit').click(function () {
$.ajax({
type: "POST",
data: { id: $(this).data('id') },
clearContent();
loadHTMLEditor(result.script);
function setEditDataId(id) {
$('#Edit').data('id', id);
function previewHTMLContent(script) {
var contentText = $("<div/>").html(script).text();
$("#htmlEditor").append(contentText);
function loadHTMLEditor(script) {
var height = $('html').hasClass('touch') ? 500 : 800,
var $igTBar = null;
$("#htmlEditor").igHtmlEditor({
height: height,
width: "98%",
customToolbars: [
collapseButtonIcon: "ui-igbutton-collapse",
expandButtonIcon: "ui-igbutton-expand",
items: [{
type: "button",
handler: appendDeleteButton,
scope: this,
props: {
isImage: {
value: false,
action: '_isSelectedAction'
imageButtonTooltip: {
value: "Clear all content",
action: '_tooltipAction'
imageButtonIcon: {
value: "ui-icon-contact",
action: '_buttonIconAction'
$("#htmlEditor").igHtmlEditor("setContent", contentText, "html");
changeToolbarsPosition();
function appendDeleteButton(ui) {
$("#htmlEditor").igHtmlEditor("setContent", "", "html");
function changeToolbarsPosition() {
$($("#htmlEditor").find("span[id*='insertObjectToolbar'].ui-igtoolbar")).insertAfter($("#htmlEditor").find("span[id*='textToolbar'].ui-igtoolbar"));
function clearContent() {
$("#htmlEditor").empty();
$("#htmlEditor").removeClass();
$("#htmlEditor").removeAttr('style');
Controller:
public ActionResult Index()
List<CRMScript> scripts = _CrmScriptRepository.GetAllScripts();
return View(scripts);
[HttpPost]
public ActionResult Display(int? id)
string script = scripts.FirstOrDefault(s => s.ID == id).Script;
if (script == null) HttpNotFound();
return Json(new {success = true, script});
Sign In
to post a reply
5 Created On
Nov 17, 2015 Last Post
10 years, 4 months ago
