Infragistics Community Forum / Web / Ignite UI for jQuery / How to right align content of a iggrid
Akhi
Akhi asked on Jul 20, 2017 2:38 PM
http://jsfiddle.net/rxb3xmjt/11/
In the above example,Currently values of Quantity is aligned to left in example
How can all the values of Quantity in iggrid  be aligned to right?.
    Vasya Kacheshmarova
    Vasya Kacheshmarova answered on Jul 17, 2017 3:56 PM
    Hello Akhi,
    Changing text alignment of igGrid`s headers or cells can be accomplished by setting the text-align property in the css classes applied to these elements. For example:
    th.ui-iggrid-header:nth-child(3){
               text-align: right !important;
     .ui-iggrid .ui-iggrid-tablebody td:nth-child(3) {
    Your modified fiddle is available here. I changed the css classes applied to the Quantity column in order to set the text-align option to right.
      Akhi
      Akhi answered on Jul 17, 2017 11:40 PM
      Hi Vasya,
      Thank you for the reply.I believe you are hard coding 3rd column.
      How can i dynamically right align columns with "Quantity"  in example to right align.
      Please provide a working copy
        Akhi
        Akhi answered on Jul 18, 2017 3:10 PM
        Can we do this in columns: attribute of iggrid?..where all "Quantity" columns can be right aligned?
        Akhi
        Akhi answered on Jul 19, 2017 3:05 PM
        I am looking for the contents of the column "quantity" to be right aligned..Can it be done on an event?.
        Please provide solution.
        Vasya Kacheshmarova
        Vasya Kacheshmarova answered on Jul 19, 2017 3:24 PM
        Hello Akhi,
        In order to select only the “Quantity” column the css selector can be modified. Each th has an id containing the column key. If the selector is modified in order to match only values that has an id ending with “Quantity” the new style is going to be applied only to these columns. For example:
        th.ui-iggrid-header[id$=Quantity]{
        Additionally, igGrid has two options that can be used foe applying styles to cells and headers:
        • columnCssClass – space-separated list of CSS classes to be applied on the data cells of this column
        • headerCssClass – space separated list of CSS classes to be applied to the header cell of this column
        $(".selector").igGrid({
            autoGenerateColumns: false,
            columns: [
                { headerText: "Product Name", key: "Name", dataType: "string", headerCssClass: "headerCss", columnCssClass: "colCss" }
        Akhi
        Akhi answered on Jul 19, 2017 7:51 PM
        Thank you Vasya!!.Appreciate your help
        Vasya Kacheshmarova
        Vasya Kacheshmarova answered on Jul 20, 2017 2:38 PM
        Hello Akhi,
Akhi
8 years, 8 months ago
Feb 24, 2026 12:16 PM
