Infragistics Community Forum / Web / Ignite UI for jQuery / igGrid column template – if statement inside each block
Paulo Ferreira
Paulo Ferreira asked on Aug 20, 2012 11:42 AM
Hi! I'm currently trying to initialize an igGrid with some conditional templating, but I'm having some problems when I use "if" statement inside "each" blocks.
Here's my columns variable:
var tempColumns = [
{ headerText: "header1", key: "Cells", dataType: "object", template: "{{each ${Cells} }} {{if ${Cells.Nome} != ''}} ${Cells.Nome} {{else}} no name {{/if}} {{/each}}", width: 250 }
My source list:
var tempSourceList2 = [{ Cells : [{ ID : 1, Nome: "Nome1" }, { ID: 2, Nome: "Nome2"}] },
{ Cells : [{ ID: 1, Nome: "" }, { ID: 2, Nome: "Nome3"}] }
But the result inside the cells on the rendered igGrid is:
if ( Nome1 != '') {result += args[0]; } else {result += args[1];} if ( Nome2 != '') {result += args[0]; } else {result += args[1];}
if ( != '') {result += args[0]; } else {result += args[1];} if ( Nome3 != '') {result += args[0]; } else {result += args[1];}
Does not the each block supports if statement?
Thank you for your attention.
    [Infragistics] Borislav Traykov answered on Aug 20, 2012 11:42 AM
    Hi Paulo,
    I'm afraid that the grid's templating capabilities do not support the "each" statement.
    However, the usage you're describing can be implemented using a formatter function instead of a template.
    You can see a basic sample of how the formatter function is used in the official sample Column Formatter.
    Hope this helps,
    Borislav
Paulo Ferreira
14 years, 1 month ago
