Infragistics Community Forum / Web / Ignite UI for jQuery / igGrid : cannot determine datasource type.
Al Maiz
Al Maiz asked on May 5, 2015 9:26 PM
hi everyone,
i’m trying to dynamically populate a grid depending on some arbitrary json output and getting
Uncaught Error: infragistics.core.js:253  Cannot determine the data source type. Please specify if it is JSON or XML data.
the json data is coming proxy.php which is doing this:
$url=”http://cnjtfs23:9090/AppManager/json/ListMonitor?apikey=f424a6c05c45381e78305a9653b56662&resourceid=10156726″;
$json=file_get_contents($url, false,$context);
echo json_encode($json);
$.ajax({
type: “GET”,
url: “proxy.php”,
contentType: “application/json; charset=utf-8”,
dataType: “json”,
success: function(res) {
$(“#monitorGrid”).igGrid({
dataType: “json”,
width: “80%”,
caption: “App Monitor”,
dataSource: res, //Array of objects defined abo
autoGenerateColumns: true
i don’t have a public access point to get to the json so i will paste as a response.
Any help is greatly appreciated.
thank you
Al
Uncaught Error: Cannot determine the data source type. Please specify if it is JSON or XML data.
    Al Maiz
    Al Maiz answered on May 1, 2015 4:03 PM
    {"response":{"result":[{"DetailsPageURL":"/showresource.do?resourceid=10156726&method=showResourceForResourceID&PRINTER_FRIENDLY=true","HEALTHATTRIBUTEID":"5001","ASSOCIATEDGROUPS":"-","RESOURCENAME":"FixFlyer Heartbeats","Managed":"true","HEALTHSEVERITY":"5","AVAILABILITYATTRIBUTEID":"5000","AVAILABILITYMESSAGE":"Resource up. <br>The resource FixFlyer Heartbeats is available.","TYPESHORTNAME":"Database Query Monitor","TYPE":"QueryMonitor","DESCRIPTION":"QueryMonitor Monitoring: for FixFlyer Heartbeats","AVAILABILITYSEVERITY":"5","RESOURCEID":"10156726","HEALTHMESSAGE":"Health of FixFlyer Heartbeats is clear. <br>Root Cause : <br>1. FixFlyer Heartbeats is up<br>2. select user_id, last_hb_time, case when (current_timestamp - interval '3' minute) > last_hb_time the is up<br>3. select user_id, current_timestamp, (systimestamp-last_hb_time) *60  as lastheartbeat_minutes, last_h is up<br>4. select user_id, current_timestamp, (systimestamp-last_hb_time) *60 as lastheartbeat_minutes, last_hb is up<br>5. select user_id, current_timestamp, (current_timestamp-last_hb_time) *60 as lastheartbeat_minutes, la is up<br>6. select user_id, current_timestamp, last_hb_time, case when (current_timestamp - interval '3' minute) is up<br>7. select user_id, to_char(current_timestamp,'YYYY-MM-DD HH24:MI:SS') as Current_TimeStamp , last_hb_ti is up<br>8. select user_id, to_char(current_timestamp,'YYYY-MM-DD HH24:MI:SS') as Current_TimeStamp , last_hb_ti is up<br>9. select user_id, to_char(current_timestamp,'YYYY-MM-DD HH24:MI:SS') as Current_TimeStamp , last_hb_ti is up<br>10. select upper(user_id) as user_id, to_char(current_timestamp,'YYYY-MM-DD HH24:MI:SS') as Current_Time is up<br>11. select upper(user_id) is up<br>12. select upper(user_id) 174174 ' HEARTBEAT' as user_id, to_char(current_timestamp,'YYYY-MM-DD HH24:MI: is up<br>13. select upper(user_id) 174174 ' HEARTBEAT' as user_id, to_char(current_timestamp,'YYYY-MM-DD HH24:MI: is up<br>14. select upper(user_id)  as user_id, to_char(current_timestamp,'YYYY-MM-DD HH24:MI:SS') as Current_Tim is up<br>15. select sub.*, case when sub.okhb=1 then 'DOWN' else 'UP' end as status FROM (SELECT USER_ID, PROD_MO is up<br>16. ffhandler-BARX_TCR-CAXTONPRD_TCR is up<br>17. ffhandler-BARX_TCR-CAXTONPRD_TCR --> STATUS  UP contains UP  (threshold).<br>18. ffhandler-BLPTSOX-CXTNTSOX is up<br>19. ffhandler-BLPTSOX-CXTNTSOX --> STATUS  UP contains UP  (threshold).<br>20. ffhandler-CITIFX-CAXTON_VELOSTP is up<br>21. ffhandler-CITIFX-CAXTON_VELOSTP --> STATUS  UP contains UP  (threshold).<br>22. ffhandler-FIXFLYER is up<br>23. ffhandler-FIXFLYER --> STATUS  UP contains UP  (threshold).<br>24. ffhandler-GTX-caxton_stp is up<br>25. ffhandler-GTX-caxton_stp --> STATUS  UP contains UP  (threshold).<br>26. ffhandler-NEOVDC-FIXFLYERDC is up<br>27. ffhandler-NEOVDC-FIXFLYERDC --> STATUS  UP contains UP  (threshold).<br>28. ffhandler-TT_ORDER-CAXTON is up<br>29. ffhandler-TT_ORDER-CAXTON --> STATUS  UP contains UP  (threshold).<br>30. ffhandler-TT_ORDER-MGSCAXTDRCL is up<br>31. ffhandler-TT_ORDER-MGSCAXTDRCL --> STATUS  UP contains UP  (threshold).<br>32. ffhandler-prod.fxgrid-order.Caxton.STP is up<br>33. ffhandler-prod.fxgrid-order.Caxton.STP --> STATUS  UP contains UP  (threshold).<br>34. validator is up<br>35. validator --> STATUS  UP contains UP  (threshold).<br>36. validatordd is up<br>37. validatordd --> STATUS  UP contains UP  (threshold).<br>","DISPLAYNAME":"FixFlyer Heartbeats","RCAPageURL":"/jsp/RCA.jsp?resourceid=10156726&attributeid=5001","HEALTHSTATUS":"clear","IMAGEPATH":"/images/queryMonitoring.gif","AVAILABILITYSTATUS":"up","LASTALARMTIME":"1430322217222"}],"uri":"/AppManager/json/ListMonitor"},"response-code":"4000"}
      Maya Kirova
      Maya Kirova answered on May 4, 2015 11:37 AM
      Hello Al,
      It seems that the json data you’re trying to bind to is wrapped in two additional objects: “response” and “result”.
      In this case the responseDataKey option of the grid should be set in order to specify the property in the response that stores the actual data records.
      In this case it should be:
      responseDataKey: "response.result"
      For more details you can refer to our Api documentation:
      http://www.igniteui.com/help/api/2015.1/ui.iggrid#options:responseDataKey
      Let me know if you have any additional questions or concerns.
      Maya Kirova
        Al Maiz
        Al Maiz answered on May 5, 2015 8:33 PM
        Hi Maya, thank you for responding.
        i'm actually using this ajax call and it's just not working. nothing is produced as output.
        wouldnt it work this way?
        $.ajax({
        type: "GET",
        url: "proxy.php",
        contentType: "application/json; charset=utf-8",
        dataType: "json",
        success: function(data)
        $("#monitorGrid").igGrid({
        width: "80%",
        caption: "App Monitor",
        dataSource: data, //Array of objects defined above
        autoGenerateColumns: true,
        <table id="monitorGrid" border=1 ></table>
        thanks again
        Al Maiz
        Al Maiz answered on May 5, 2015 8:41 PM
        since i'm encoding it in the php file, do i need to decode it when setting the grid data source. do i have to escape characters? this is a part of the exact text coming php get.
        "{\"response\":{\"result\":[{\"DetailsPageURL\":\"\/showresource.do?resourceid=10156726&method=showResourceForResourceID&PRINTER_FRIENDLY=true\",\"TODAYUNAVAILPERCENT\":\"0.0\",\"Attribute\":[{\"DISPLAYNAME\":\"Response Time\",\"Value\":\"182\",\"Units\":\" ms\",\"AttributeID\":\"5002\"}],\"HEALTHATTRIBUTEID\":\"5001\",\"TARGETADDRESS\":\"\",\"RESOURCENAME\":\"FixFlyer Heartbeats\",\"TODAYAVAILPERCENT\":\"100.0\",\"TARGETNAME\":\"\",\"TODAYSCHEDDOWNPERCENT\":\"0.0\",\"AVAILABILITYATTRIBUTEID\":\"5000\",\"HEALTHSEVERITY\":\"5\",\"DISKUTIL\":\"-1\",\"MANAGED\":\"true\",\"PHYMEMUTIL\":\"-1\",\"AVAILABILITYMESSAGE\":\"Resource up.
        The resource FixFlyer Heartbeats is available.\",\"AVAILABILITYSEVERITY\":\"5\",\"TYPESHORTNAME\":\"Database Query Monitor\",\"TYPE\":\"QueryMonitor\",\"DESCRIPTION\":\"QueryMonitor Monitoring: for FixFlyer Heartbeats\",\"LASTPOLLEDTIME\":\"May 5, 2015 3:37 PM\",\"RESOURCEID\":\"10156726\",\"TODAYUNMANGDPERCENT\":\"0.0\",\"HEALTHMESSAGE\":\"Health of FixFlyer Heartbeats is clear.
        Root Cause :
        Al Maiz
        Al Maiz answered on May 5, 2015 9:26 PM
        found the problem….wasn't serializing to javascript
        dataSource: jQuery.parseJSON( data ),
        jQuery.parseJSON()
        Al
Al Maiz
11 years, 4 months ago
May 5, 2015 9:26 PM
Feb 20, 2026 12:46 PM
