Get values from multi column list view
Brian
Brian asked on Apr 19, 2011 5:00 PM
Good morning,
I have a control showing as a SwfListView in our application.  The list has 2 columns.  I can get the item count with the code below and the value of the first column. How do I get the associated value in the 2nd column?
'Build the output sheet to see what we have for values
sheetNameOutputData = "Output Data"
DataTable.AddSheet(sheetNameOutputData)
Set DTOuptputData = DataTable.GetSheet(sheetNameOutputData)
'Create the columns
columnName = "Value"
EmpltyData = ""
EmptyData = DTOuptputData.AddParameter(columnName, "").Name
var_GetItemsCount = SwfWindow("Summit FT Diagnostics").SwfListView("environmentListView").GetItemsCount()
For loopItems = 1 to var_GetItemsCount
 'Set the output row
 DTOuptputData.SetCurrentRow(loopItems)
 strItemValue = SwfWindow("Summit FT Diagnostics").SwfListView("environmentListView").GetItem(loopItems – 1) 'Subtract 1 since index starts with zero
 'Output the data
 DTOuptputData.GetParameter(columnName).Value = strItemValue
Next
'Header in the object show 2 columns
var_GetColumnHeader = SwfWindow("Summit FT Diagnostics").SwfListView("environmentListView").GetColumnHeader(1)
Brian Washburn
    Michael Germann
    Michael Germann answered on Apr 19, 2011 5:00 PM
    There are two possibilities. You can use GetColumnContent(sColName or iColIndex), which will get you all the values for that particular column.
    Or you can use GetNAProperty(sPropertyPath)
    Something like the following:
    Set ListView = SwfWindow("Form1").SwfListView("ultraListView1")
    msgbox ListView.GetNAProperty("Items[1].SubItems[0].Text")
Brian
15 years, 5 months ago
