Get the selected value of a cell
Ceaser
Ceaser asked on Jul 24, 2008 4:35 PM
I am getting an exception (null reference) while taking the active cell value in wingrid.
rowIndex = this.ultraGrid1.ActiveCell.Row.Index;
this.ultraGrid1.Rows[rowIndex].Cells[“CellName”].Value.ToString();This execption is obtained when the rows are filtered., and if the rows are not filtered there is no error
Pgr2007
    Matt Snyder
    Matt Snyder answered on Jul 21, 2008 3:55 PM
    I'm not sure why this is happening, since the same code works for me when I tested it when all but one row was filtered out.  Is the null reference exception coming from your code (i.e. "this.ultraGrid1.Rows[rowIndex]" returning null) or from somewhere inside the grid?
    -Matt
      Vince
      Vince answered on Jul 22, 2008 12:52 PM
      6 of 1, half dozen of the other, this works for me.
                   string s = ultraGrid.ActiveRow.Cells["TransactionID"].Text;
      And while I'm here, I'm on my 2nd day of evaluation.  One thing causing me confusion, and the reason I ended up here in the forums, I was expecting the above line of code to be written as
                   string s = ultraGrid.ActiveRow.Columns["TransactionID"].Text;
      I basically wanted to be able to read any of the column values for the currently selected row.  I guess I have to use "Cells" not "Columns" for this, but what I don't understand is, there is a "Columns" property, albeit,
                  ultraGrid.ActiveRow.Band.Columns["TransactionID"]
      What I don't understand is why I can't read the column value out of the columns collection.  And why "Cells" seems to be used as what I call a "Column".  Any insight on the difference between "Cells" and "Columns" in the grid would be appreciated.
      Thanks.
        Mike Saltzman answered on Jul 22, 2008 3:30 PM
        A column is an entire columns. It's a range of cells representing the same cell in each row. A cell is a single cell – it is the intersection of a row and a column.
        Ceaser
        Ceaser answered on Jul 24, 2008 4:26 PM
        I got when I am getting exception. If I have sorted(grouped) the grid based on any column exception is thrown otherwise none.
        Pgr2007
        Ceaser
        Ceaser answered on Jul 24, 2008 4:35 PM
        this
        .ultraGrid.DisplayLayout.Bands[0].Columns["Column"]
        pgr2007
Ceaser
17 years, 7 months ago
Feb 11, 2026 5:20 PM
