Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / Parser Error Message: Unrecognized configuration section configsections.
vasanth
vasanth asked on May 27, 2010 12:40 PM
Hi all,
My web.config section looks like this,
<?xml version=”1.0″?>
Note: As an alternative to hand editing this file you can use the
web admin tool to configure settings for your application. Use
the Website->Asp.Net Configuration option in Visual Studio.
A full list of settings and comments can be found in
machine.config.comments usually located in
\Windows\Microsoft.Net\Framework\v2.x\Config
<configuration>
<configsections>
<section name=”infragistics.web” type=”System.Configuration.SingleTagSectionHandler,System, &#xA;     Version=1.0.3300.0, &#xA;     Culture=neutral, &#xA;     PublicKeyToken=b77a5c561934e089″/>
<sectiongroup name=”system.web.extensions” type=”System.Web.Configuration.SystemWebExtensionsSectionGroup, System.Web.Extensions, &#xA;      Version=3.5.0.0, &#xA;      Culture=neutral, &#xA;      PublicKeyToken=31BF3856AD364E35″>
<sectiongroup name=”scripting” type=”System.Web.Configuration.ScriptingSectionGroup, System.Web.Extensions, &#xA;       Version=3.5.0.0, &#xA;       Culture=neutral, &#xA;       PublicKeyToken=31BF3856AD364E35″>
<!–<section name=”scriptResourceHandler” type=”System.Web.Configuration.ScriptingScriptResourceHandlerSection, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35″ requirePermission=”false” allowDefinition=”MachineToApplication”/>
<sectionGroup name=”webServices” type=”System.Web.Configuration.ScriptingWebServicesSectionGroup, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35″/>
<section name=”jsonSerialization” type=”System.Web.Configuration.ScriptingJsonSerializationSection, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35″ requirePermission=”false” allowDefinition=”Everywhere”/>
<section name=”profileService” type=”System.Web.Configuration.ScriptingProfileServiceSection, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35″ requirePermission=”false” allowDefinition=”MachineToApplication”/>
<section name=”authenticationService” type=”System.Web.Configuration.ScriptingAuthenticationServiceSection, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35″ requirePermission=”false” allowDefinition=”MachineToApplication”/>
<section name=”roleService” type=”System.Web.Configuration.ScriptingRoleServiceSection, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35″ requirePermission=”false” allowDefinition=”MachineToApplication”/>–>
</sectiongroup>
</sectiongroup>
</configsections>
<INFRAGISTICS.WEB formsDirectory=”~/WebSchedule”/>
<system.web>
Set compilation debug=”true” to insert debugging
symbols into the compiled page. Because this
affects performance, set this value to true only
during development.
Visual Basic options:
Set strict=”true” to disallow all data type conversions
where data loss can occur.
Set explicit=”true” to force declaration of all variables.
<compilation debug=”true” strict=”false” explicit=”true”>
<assemblies>
<add assembly=”Infragistics2.WebUI.WebSchedule.v6.2, Version=6.2.20062.34, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB”/>
<add assembly=”Infragistics2.WebUI.Shared.v6.2, Version=6.2.20062.34, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB”/>
<add assembly=”System.Design, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A”/>
<add assembly=”Infragistics2.WebUI.WebScheduleDataProvider.v6.2, Version=6.2.20062.34, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB”/></assemblies>
<codeSubDirectories>
<add directoryName=”VBCode”/>
<add directoryName=”CSCode”/>
</codeSubDirectories>
</compilation>
<pages>
<namespaces>
<clear/>
<add namespace=”System”/>
<add namespace=”System.Collections”/>
<add namespace=”System.Collections.Specialized”/>
<add namespace=”System.Configuration”/>
<add namespace=”System.Text”/>
<add namespace=”System.Text.RegularExpressions”/>
<add namespace=”System.Web”/>
<add namespace=”System.Web.configuration”/>
<add namespace=”System.Web.Caching”/>
<add namespace=”System.Web.SessionState”/>
<add namespace=”System.Web.Security”/>
<add namespace=”System.Web.Profile”/>
<add namespace=”System.Web.UI”/>
<add namespace=”System.Web.UI.WebControls”/>
<add namespace=”System.Web.UI.WebControls.WebParts”/>
<add namespace=”System.Web.UI.HtmlControls”/>
</namespaces>
</pages>
The <authentication> section enables configuration
of the security authentication mode used by
ASP.NET to identify an incoming user.
<authentication mode=”Windows”/>
The <customErrors> section enables configuration
of what to do if/when an unhandled error occurs
during the execution of a request. Specifically,
it enables developers to configure html error pages
to be displayed in place of a error stack trace.
<customErrors mode=”RemoteOnly” defaultRedirect=”GenericErrorPage.htm”>
<error statusCode=”403″ redirect=”NoAccess.htm” />
<error statusCode=”404″ redirect=”FileNotFound.htm” />
</customErrors>
</system.web>
</configuration>
And am getting,
” Unrecognized configuration section configsections. “
as the error message….
Can anyone help me out of this problem…!!!
    Derek Harmon
    Derek Harmon answered on May 26, 2010 7:06 PM
    [quote user="vasanth_krt"]
    <configuration>
         <configsections>
    And am getting,
    " Unrecognized configuration section configsections. "
    [/quote]
    Change "configsections" to "configSections" with a capital S (do this to both the start tag and the end tag near the end of the file.)  XML is case-sensitive.
      vasanth
      vasanth answered on May 27, 2010 12:40 PM
      Thanks for the reply….!!
      Ur reply helped me a lot… N now am getting the output properly…
      Nice work…!!
vasanth
16 years, 4 months ago
Feb 18, 2026 11:19 AM
