Infragistics Community Forum / Web / Ignite UI for Angular / Can I remove any column checkbox from show/hide column dropdown?
Minakshi Mitra Kundu
Minakshi Mitra Kundu asked on Jan 15, 2021 10:09 AM
Out of 7 columns, last column contain a delete icon without a column header. I do not want to show this column checkbox(as it appears blank without the header) in the show/hide dropdown.
As it can be seen in the below image, one blank checkbox is listed down. Can this blank checkbox be removed programmatically?
    Martin Evtimov
    Martin Evtimov answered on Jan 14, 2021 5:06 PM
    Hello Minakshi,
    In order to remove a column from the default column hiding dropdown list (placed within the igxGrid toolbar) you can set the column’s disableHiding property to true as stated in the Disable hiding of a column section within the Column Hiding topic. Please note that this will not only remove the column from the list but indeed when clicking over the “Hide All” button the column decorated with the disableHiding property will remain in the grid.
    In your case after clicking over the “Hide All” button all of the columns will get hidden except for the one containing the delete buttons. If you want to not let this column to be the only one which is not hidden an additional logic should be implemented on application level. You can refer to the following sample I have prepared for you. As you can observe, subscribing to the hiddenChange event (emitted when a column changes its hidden property) of each igxGrid’s columns you can invoke a function checking the number of the visible columns within the grid and applying your own logic depending on this number.
    In the attached sample if all of the columns except the one containing the delete buttons (deleteColumn) are hidden, the deleteColumn would be hidden as well. If at least one of those columns is visible, the deleteColumn would be visible as well.
    Please keep in mind that as mentioned this should be implemented on application level which is beyoud of the scope of Infragistics support. Having this in mind, we will not update the provided sample with any additional implementation but you can feel free to ask questions regarding the current approach.
    Martin Evtimov
      Minakshi Mitra Kundu answered on Jan 15, 2021 7:21 AM
      Thanks for the quick response.
        Martin Evtimov
        Martin Evtimov answered on Jan 15, 2021 10:09 AM
        Hello Minakshi,
        I’m glad that you find the provided information helpful.
        Please let me know if you need any further assistance regarding this matter.
        Martin Evtimov
5 years, 9 months ago
Feb 11, 2026 10:32 AM
