Canceling Tab Change – UltraWinTabControl
New DiscussionMaybe this is not the correct control to do what I'm trying to do, but ..
I have an UltraWinTabControl with several tabs on the top of my form, the bottom of my form is an UltraWinGrid.
I am using the .ActiveTabChanged event to set the datasource of the Grid based on the ActiveTabChangedEventArgs Tab.Key property.
What I am looking for is a means to see what tab I am leaving BEFORE I leave it because I would like to:
1) check that the grid data has been saved, and cancel the tab change if not.
2) Save any user applied filters to the grid for that tab to re-apply when the tab becomes active again
I cannot seem to find any means to do this BEFORE the actual change happens.
The ActiveTabChangedEventArgs has a .PreviousTab property but by the time this event fires, the change is completed and it has no .Cancel property
The ActiveTabChangingEventArgs has a .Cancel property but the .Tab property still points to the tab it's changing into not the one it's leaving and it has no .PreviousTab property.
I suppose I could do everything in the AfterTabChanged event and then switch back to the .PreviousTab if it fails but the fact that .ActiveTabChanging has a .Cancel property makes me think there should be a cleaner / simpler way to do this.
Am I missing something or is there a better way to handle this?
Steve
