Infragistics Community Forum / Web / Ignite UI for Blazor / Binding to a Nested Object in Blazor DataGrid
Matthew Cuda
Matthew Cuda asked on Dec 16, 2021 3:31 PM
How would I bind a datagrid column to a nested object?
For example:
<TextColumn IsEditable = “false” Field=”AssignedSeverity.Name” HeaderText=”Severity” Width=”@(“*>120″)” />
//FRAGMENT OF CLASS BELOW
public class Request
private int _id = -1;
private string _problem = string.Empty;
private string _solution = string.Empty;
private Severity _assignedSeverity = new Severity();
public int Id { get => _id; set => _id = value; }
public string Problem { get => _problem; set => _problem = value; }
public string Solution { get => _solution; set => _solution = value; }
public Severity AssignedSeverity { get => _assignedSeverity; set => _assignedSeverity = value; }
    Andrew Goldenbaum
    Andrew Goldenbaum answered on Dec 16, 2021 3:31 PM
    Hello Matthew,
    At the time of writing this, the Ignite UI for Blazor DataGrid does not support binding the Field property of its columns to complex/nested objects. The best thing I can recommend at the moment is that you flatten out your data as it pertains to the grid.
    For example, I see you are trying to bind to AssignedSeverity.Name. I am assuming this is probably a string property, and so you can define a new string property on your Request class that returns AssignedSeverity.Name and then point your TextColumn’s Field at that property.
      Matt Wills
      Matt Wills answered on Jun 10, 2022 2:17 PM
      Or you could use CellTemplate to access the nested property
      <Column T="Model" Field="HireDate" Title="Hired">
                  <CellTemplate>
                      @context.Item.HireDate.ToString("d")
                  </CellTemplate>
              </Column>
Matthew Cuda
4 years, 3 months ago
Feb 11, 2026 9:52 AM
