Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / Bind to DataTable Column.Caption Instead of ColumnName
Arseny
Arseny asked on Sep 16, 2013 9:59 AM
DataTable dt = new DataTable();
dt.Columns.Add(“col1”).Caption = “column one”;
dt.Columns.Add(“col2”).Caption = “column two”;
dt.Columns.Add(“col3”).Caption = “column three”;
dt.Rows.Add(“val11”, “val12”, “val13”);
dt.Rows.Add(“val21”, “val22”, “val23”);
DataView dv = new DataView(dt);
WebDataGrid1.DataSource = dv;
WebHierarchicalDataGrid1.DataSource = dv;
After performing this code you will see WebDataGrid with Captions from DataTable (dt)
And WebHierarchicalDataGrid will show ColumnNames (instead of Captions) from DataTable (dt)
Why and how to fix it?
    Maya Kirova
    Maya Kirova answered on Sep 16, 2013 9:59 AM
    Hello arseny ,
    WebHierarchicalDataGrid should not be bound  to a non-hierarchical data source like a data table. If you want to have a WebHierarchicalDataGrid with a single level of data you can bind it to a DataSet with just one  DataTable. For example:
            DataSet set = new DataSet();
            set.Tables.Add(dt);
            WebHierarchicalDataGrid1.DataSource = set;
    Maya Kirova
    Developer Support Engineer II
Arseny
12 years, 10 months ago
Feb 11, 2026 4:08 PM
