Hi
First: sorry for the bad English After loading the layout and display a previously invisible group we not adopted the theme. For a better understanding I have attached a small example. 1 Remove one of the dialogue Group (Use your built-in Dialog). 2 Save Layout 3 Load Layout 4 Show group. Theme is not assumed.
Hello Marcus,
Our developers have researched this behavior for you.
If you want to save/load the styles using Control Persistence Framework you have to define the styles in the App.xaml file. Then apply the identifier attached property. For more information on how you can apply this property you can take a look at the following link: http://help.infragistics.com/Help/Doc/Silverlight/2014.1/CLR4.0/html/Persistence_Identifier.html.
Please do not hesitate to let me know if you have any further questions on this matter.
I have logged this behavior with our developers in our tracking system, with an issue ID of 174380. I have also created a support ticket on your behalf with number CAS-139551-B8H2R7 in order to link the development issue to it so that you are automatically updated when a Service Release containing your fix is available for download.
Thanks for the quick reply ... Please test it with the built-in dialog box (see image). Thank you
Thank you for your post.
I have been looking into the sample application you have provided and I am not able reproduce the issue you have mentioned. I have created a small sample application for you to see the behavior on my side. I have used the steps to reproduce you have given.
Would you please provide me with more detailed information regarding the environment in which you are developing your application (Operating system, Service Release, Integrated development environment and the specific version of our product that you are using and any other information that might help reproducing your issue), in order to be able to identify what might be causing this behavior?
Thank you for the cooperation. Looking forward to hearing from you.
