Hi, I'm using version 12.1,and I encountered some problems about zoombar.
Please see details in the attached picture.
Thanks very much~~
Hello Charlie,
Hi Charlie,
Thank you for your reply. Regarding your first post you are explaining that you would like to use the XamZoombar only for the plot area of the XamDataChart(without covering the labels area). This is why I suggested you insert the XamZoombar using code-behind in order to remove the canvas that holds the plot area, add the XamZoombar and after that add the canvas again. This functionality cannot be achieved using XAML only.
If you would like the XamZoombar to cover the entire XamDataChart, you need to remove the ‘Loaded’ event handler of the XamDataChart.
Let me know, if you need any further assistance on this matter.
Hi Yanko,
I'm not very clear about the question "xamzoombar cover the chart" in the solution you provided .
In your solution, you created the xamzoombar in the code-behind, but in my project, the xamzoombar is defined in the xaml page. So I try to modify the solution you provdeded to meet my requirement, but it didn't work, the dataChart is missing, only a zoomBar.
I have attached the modified solution. Please help.
Thank you for your reply. Currently the thumb of the XamZoombar cannot be moved horizontally and vertically at the same moment. This depends from the ‘Orientation’ of the XamZoombar itself.
You can suggest new product ideas for future versions (or vote for existing ones) at <http://ideas.infragistics.com>.
There are many benefits to submitting an product idea:
- Direct communication with our product management team regarding your product idea.
- Notifications whenever new information regarding your idea becomes available.
- Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.
- Allow you to shape the future of our products by requesting new controls and products altogether.
- You and other developers can discuss existing product ideas with members of our Product Management team.
Steps to create your idea:
1. Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).
2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
3. Add your product idea and be sure to be specific and provide as much detail as possible. Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
The Product Idea site puts you in the driver’s seat and allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
