Hello Infragistics-Support-Team!
Since I changed to version 2014.1, I have noticed that the input via mouse/keyboard together with clipboard doesn't work so easily as before.
Before (2013.2) you could just select a time/date of the input and copy/paste it immediatly.
Now (2014.1) I have to use the right mouse button, click on "Select All" and only then I can copy the data to the clipboard.After that I have to do the same/similar sequence to put the data back in.
Am I missing something? What do I have to do, to overwrite the input directly via clipboard functions.
Hint: My XamDateTimeInput-Elements are bound to corresponding DateTime-Properties.I'm building/optimizing a Date/Time-Selection-Screen.
Best regardsStefan Schmitt
Hello Stefan,
This was resolved in the July service releases for 13.1 - 14.1.
Sincerely,Valerie Developer Support Supervisor - XAMLInfragisticswww.infragistics.com/support
Hi Valerie,
I have the same issue. Is this issue resolved?
Best regards,
Stefan
Thank you Valerie!
Then I was a little too quick with installing the SRs... :-).
I'll wait for now until you have an update - otherwise I would have to downgrade to before SRs.This would probably mean reinstalling the version 2014.1 - so for now I'll just wait
Best regards
Stefan Schmitt
I do see the issue with the service release and I have asked our engineering staff to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 171263. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
I have also created a private case for you, CAS-136485-W8Z8D9, to notify you of any changes in the status of this issue.
Sincerely,
Valerie
Very interesting Valerie!
I had already updated my version 2014.1 with the first SRs.
So I have the version 14.1.20141.2027!In this version it is not possible to copy the date directly, I had to first select "Select all" from the right click drop down menu.
The only thing I changed on your example was, that I downgraded it from the 4.5.1 to the 4.5 .NET Framework.
Could you, please, double check if this issue happens on your side too with the newer SRs?
Thank you!
