200
Unbound field datatrigger (generic)
I've created a custom Unbound field and a style for it as well.
<igDP:UnboundField x:Class="My.Grids.Controls.FieldTypes.TradingStatusField"
                             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
                             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
                             xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
                             xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
                             xmlns:sys="clr-namespace:System;assembly=mscorlib"
                             xmlns:igDP="http://infragistics.com/DataPresenter"
                             xmlns:igEditors="http://infragistics.com/Editors">
    <igDP:Field.Settings>
        <igDP:FieldSettings LabelTextAlignment="Left" EditAsType="{x:Type sys:String}" DataValueChangedNotificationsActive="True"
                                    AutoSizeOptions="All" AutoSizeScope="AllRecords">
             <igDP:FieldSettings.EditorStyle>
                 <Style TargetType="{x:Type igEditors:XamTextEditor}">
                      <Setter Property="HorizontalContentAlignment" Value="Left"/>
                 </Style>
             </igDP:FieldSettings.EditorStyle>
         </igDP:FieldSettings>
    </igDP:Field.Settings>
</igDP:UnboundField>
<Style x:Key="TradingStatusStyle" TargetType="{x:Type igDP:CellValuePresenter}" BasedOn="{StaticResource {x:Type igDP:CellValuePresenter}}">
    <Setter Property="Foreground" Value="Orange"/>
    <Style.Triggers>
        <DataTrigger Binding="{Binding ?" Value="Trading">
            <Setter Property="Foreground" Value="#00A300"/>
        </DataTrigger>
        <DataTrigger Binding="{Binding ?}" Value="Closed">
            <Setter Property="Foreground" Value="Red"/>
        </DataTrigger>
     </Style.Triggers>
</Style>
How can I have the trigger bind to the BindingField property of the cell?
I won't know if the user will call the property Status or TradingStatus or Foo for that matter beforehand and since this is an unboundField I don't know the level of nesting that will be bound to this field i.e.
<my:TradingStatusField BindingPath="SomeParent.ItsChild.AndGrandChild.Status"/>
How can I in the style get to the last property in the BindingPath and trigger on that value?
Cheers,
  nisbus
  • 200
    Verified Answer
    Well, I found a way to do it:
        <Setter Property="Template">
            <Setter.Value>
                <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
                    <TextBlock VerticalAlignment="Center" HorizontalAlignment="Center"
                                     Text="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Value}">
                        <TextBlock.Style>
                            <Style TargetType="{x:Type TextBlock}">
                                <Style.Triggers>
                                        <DataTrigger Binding="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Value}" Value="Trading">
                                        </DataTrigger>
                                        <DataTrigger Binding="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Value}" Value="Closed">
                                        </DataTrigger>
                                </Style.Triggers>
                            </Style>
                        </TextBlock.Style>
                    </TextBlock>
                </ControlTemplate>
           </Setter.Value>
        </Setter>
    </Style>
    I hope it helps someone
