Can I implement below function:
In my xamDataChart, I can choose one data point, and then use keyboard (left or right) to choose left data point or right data point?
Do I make myself clearly? Sorry for my poor English..
Hi Stefen,
Thank you~~~
Hello Charlie,
I have added the functionality you want in the sample. Since the Tooltip that is used for the Series is not the default WPF tooltip, but a custom PopUp, you should set its position and text manually when you want to open it via code behind. I set the needed Properties, so now when the arrow keys are pressed and the point is colored the tooltip also opens. I handled the MouseMove event, so I could be able to set the binding again for the cases when you hover with the mouse.
Hi Stefan,
You really have done me a big favor. And trouble you again, can I implement below function?
When I clicked one point, I need show the tooltip data, and when I use left arrow or right arrow to move the point, show the updated tooltip data.
Thanks really really for your help.
I have been looking into the sample and I can say that this behavior is expected, because the ToolTip is update when you hove over a Marker. I modified the sample, so now it works as you want. Basically get the current Msrker's Content, which contains the underlying object.
Hi Steven,
I have another question. Please help.
I have modified your sample code to implement the "keyboard moving" function, and I have a new requirement: when I click one point, then press the Enter key, show the point's value. When I use left arrow key or right arrow key to move the point, then press the Enter key, show the current point's value. In my solution, I was trying to use tooltip to show the point's value, and when I press the Enter key, show the tooltip value. But the question is : When I use left arrow key or right arrow key to move the point, then press the Enter key, the value isn't what the current's point's value.
Do I make myself clearly? Please see attached. Thanks~~
