Details please refer to below .PNG file. Thanks in advance~
OK. Thanks for your help. ^_^
Hello Charlie,
Yes that is right, because the XamZoombar is a complicated control and the border you want to make thinner is in fact a custom control. You can also add a ResourceDictionary and put the Style there, if you don't want to put it in XAML.
Hope this helps you.
Thanks.
So if I want to implement this functionality, I have to copy this default style into my XAML file, and do some change? Because I find that the default style xaml code is about 900 line~~~
You can find the default Styles here by default:
C:\Program Files (x86)\Infragistics\NetAdvantage 2013.1\WPF\DefaultStyles
Hi Stefan ,
Thanks for your response, and where can I find the default style of these control?
