How can i change the width of the expansion indicator both at the header/cell control. If i set the width of the cell to a smaller one i see the other columns do no re-arrange, so possible there is a static one time binding, can you tell how this can be achieved?
Rohit
Hello Rohit,
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
Thank you for your email. Looking forward to hearing from you.
Sorry it didn't work in my case, i will try to create a sample for you later this week.
I have looked into the sample and the reason the style is not applied is that it should be set for the ExpansionIndicatorCellControl. Please excuse me for the misunderstanding as I have suggested using the RowSelectorCellControl style in my previous post. The row selector could be used when the RowSelectorSettings is set to visible which is not the case here.
I have attached a sample application using the code you have provided. Please feel free to let me know if this is the functionality you are looking for.
