i've a question on XamDataGrid.
I sort a XamDataGrid programmatically, after this I want to prevent user sorting, by click on column header. Is it possible?
Andrea
Could you please provide me sample for using SortComparer property of the XamDataGrid.
I have written sample class as follows
Implements IComparer
End Sub
Public Function Compare(ByVal x As Object, ByVal y As Object) As Integer Implements System.Collections.IComparer.Compare
End Function
End Class
and set SortComparer property as follows :
Dim iComparer As IComparer
parentCaptionField.Settings.SortComparer = iComparer
But still XamDataGrid does not do the sorting..
Please suggest what can be the issue...
Vinod Sa.
Sorry just forgot, setting e.Cancel = true; should do it;
Even if I set e.handled = true the grid Sort his data on ColumClick.
Handle Grid.Sorting event and in the handler set e.handled = true.
This way XamDataGrid will not sort the grid on ColumnClick.
As an alternative you can also write you own SortComparer and supply it to grid.
obviously I want maintan the programmatically order.
