Hi
In XamDataGrid I want to bind "ExpansionIndicatorVisibility" for each Record based on Condition (based on column value present in DataSet/DataTable) in XAML
can anybody suggest me how can I do that in XAML?
Hello Naitik,
Hi Stefan,
Thanks for your solution.
Currently I am accessing cell value using "Column Name". and I am binding different Dataset to XamDataGrid. so DataSet may not contain that "Column Name" at
that time i am getting error in converter. I did some workaround but I don't think it is a good way when I have millions of records and lot of Columns (Fields).
Is there any other way to achieve that?? I have Attached my Convertor file.
My Final Goal is to achieve the functionality which is Combination of CheckOnDisplay + CheckOnExpand (If there is child record then it should display Expansion sign else not. and when Parent Expands it should fetch child records)
I have already set FieldLayoutSettings.ExpansionIndicatorDisplayMode = ExpansionIndicatorDisplayMode.CheckOnExpand in my code.
Thanks & Regards,
Naitik
I am not able to bind "Loaded" event in resource dictionary using EventSetter. Problem is Event is in different xaml.cs file then resource dictionary.
can you guide me how to bind EventSetter to event (which is in other xaml.cs file) in Resource Dictionary??
I have modified the sample I sent you before and now there aren’t event handlers, only relay commands for the DataRecordPresenter’s Loaded event. Please let me know if this helps you or you need further assistance on this matter.
Thank you very much for your sample example. It worked as expected.
Thanks once again.
Thanks again.
