I am using xamdatagrid, with autogenerate off. I want to display a tool tip for each cell which is just the value in the cell. But I can't make it work.
I have tried the 'style' approach that I found else where in the forum, but i get an error saying I cant do that if items has been added which I am inferring has to do with the autogenerate = false.
<Style TargetType="{x:Type igDP:CellValuePresenter}">
<Setter Property="ToolTip" Value="{Binding RelativeSource={RelativeSource Self},Path=Value}"></Setter>
</Style>
I have also tried something like this to set the tooltip in the fieldproperties portion of the xaml but cannot describe the path to the data in a way wpf can understand me.
igDP:Field Label="Timestamp" Name="entry_tstmp" ToolTip="{Binding RelativeSource={RelativeSource Self},Path=Value}" Width="80" >
I have been looking into your question and you cannot set the tooltip for a Field in this way because this way you are setting only the tooltip for CellValuePresenter (referring its value). If you would like to activate the tooltip for a particular Field only you need to create a style to a CellValuePresenter and to refer it in the field settings for this Field like e.g. :
<Style x:Key="cvp" TargetType="{x:Type igDP:CellValuePresenter}">
<Setter Property="ToolTip" Value="{Binding RelativeSource={RelativeSource Self},Path=Value}">Setter>
Style>
<igDP:Field Name="FirstName" Label="Name">
<igDP:Field.Settings>
<igDP:FieldSettings CellValuePresenterStyle="{StaticResource ResourceKey=cvp}"/>
igDP:Field>
If you need any further assistance on this matter, feel free to ask.
