100
ResourceWasher overridden by DataRecordCellAreaStyle
I have issues while adding the Metro-Theme to my application.
I'm using the ResourceWasher in MainWindow.xaml to change everything (for example: hover in the xamdatagrid) to the Metro-Look. I'm now trying to change the BackgroundColor of a single XamDataGrid-Row by adding a style targeting the DataRecordCellArea. Unfortunately it seems that the Style is overriding the ResourceWasher, hence the metro-hover gets changed to the default IG-hover....
How can I accomplish a clean inheritance of the Metro-Style to all controls without cutting the possibility to add styles?
MetroStyleInheritnaceTest.zip
  • 138253
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post and I modified the sample you attached, so now it works as you want. Basically I copied the whole Style for the DataRecordCellArea that is used in the Metro theme, because when you set the new one, the default one is overridden as you noticed.
    MetroStyle.zip
