When I'm dragging a certain pane over another pane, I would like to hide the center indicator in order to prevent users to dock this way.
For the moment, I only succeded in preventing the drop with this chunk of code (on the PaneDragOver event), which works well :
private void ultraDockManager1_PaneDragOver(object sender, Infragistics.Windows.DockManager.Events.PaneDragOverEventArgs e)
if (e.DragAction is AddToGroupAction)
e.IsValidDragAction = false;
e.Cursor = Cursors.No;
if (e.DragAction is NewTabGroupAction)
if ((e.DragAction as NewTabGroupAction).Pane.Name.Contains("Navigateur") && e.Panes.Count > 0 && e.Panes[0].Name.Contains("Navigateur"))
return;
if (e.DragAction is NewSplitPaneAction)
The cursor is then showed as a crossed circle, preventing the drop.
But the users would prefer not to see the center indicator than see it disabled. Is there any way of hiding this control ? (only the center one, not the others)
Many thanks in advance,
Thomas
Hello Thomas,
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Yes it works great !
I adapted a bit the code to completely hide the center DockingIndicator (rather than just hiding the center card panel) :
protected void DockingIndicator_Loaded(object sender, RoutedEventArgs e)
DockingIndicator di = sender as DockingIndicator; if (di == null) return; if (di.Position == DockingIndicatorPosition.Center) di.Visibility = Visibility.Hidden; }
if (di == null)
You can change the post status to "Solved".
Thanks again !
Thanks again.
