Is there a programatic way to ensure that a parent node can only have 1 checked child? For instance, consider the following tree:
Marital Status
Single
Married
So if you click Single the code will ensure that the Married not will not be checked. Much like a radio buttons...
Any ideas?
ah yeah the infragisitcs control was too difficult to use... so i went back to the .net control. Everything works great and seems to be faster than infragistics
Hello Aaron,
I have modified the sample again and now if you click a child node, the parent is also selected and also the NodeCheckChnage is fire only once because I handled and unhandled the event. Please let me know if you require any further assistance on this matter.
Well yeah that will work... also if you just set the CheckMode to Auto that will work even better.
The issue is the NodeCheckChange fires multiple times. I need it to fire once when a child is checked and have the parent nodes checked.
THe reason is i need to create a contextual representation of the nodes that are clicked to the right of the treeview. The Text version gets created multiple times when the checked procedure fires multiple times.
I have modified the sample again and now if you click a child node, the parent is also selected, which I believe is the functionality you want to achieve. Please let me know if you require any further assistance on this matter.
