I want to use Multiple Charts option, along with dynamic data display.
Previously seeing that binding directly xamChart with ViewModel is not allowed, We have to use certain classes for using DataBinding.
http://community.infragistics.com/forums/t/55296.aspx
So, just want to ask what procedure do I have to follow to reuse the same classes in order to show Multiple Charts within the same chart, though Data binding with MVVM.
Code snippet will be highly appreciated.
VJ
Hello VJ,
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
If this is what you were looking for please verify the answer so it helps other users as well.
I have been looking into your description however I am not sure I completely understand what is your requirement. If you are trying to use multiple Series in one XamChart, please let me know what kind of Series are they so I can verify if they are compatible.
Thanks in advance. Looking forward to hearing from you.
