I created report, set PageFooterTemplate, PageHeaderTemplate and PageContentTemplate. Then was added section which contains XamDataGrid. In PageHeaderTemplate there is a trigger which manages the content of Header depending page number (on first page height of header is 200, on other pages is 100). And here is what I have:
I lost the rows between 33 and 39. I attached file with an example.
I solved this problem using example from topic http://forums.infragistics.com/forums/t/39755.aspx
