473
Caret is visible even after setting the ReadOnly to true in XamMaskedEditor
I am setting XamMaskedEditor's  IsReadOnly property to true. Now if I use mouse to focus on the XamMaskedEditor the caret blinks inside the XamMaskedEditor. Is it the default behavior or a defect.
If I use the XamTextEditor the caret is not visible inside the XamTextEditor.
Please find a sample attached here.
Steps to reproduce -
1. Run the application.
2. Click on the XamMaskedEditor using mouse.
3. The caret blinks inside the XamMaskedEditor.
Sachin
WpfStudy.zip
  • 27093
    Hello Sachim,
    I have been looking into your issue and I can see what you mean. I guess that this is so, since there isn’t much point in using a mask editor for a  readonly field. Nevertheless I found a way for you to hide the caret when the masked editor is readonly. I have made this code snippet based on the sample project you had uploaded:
    <igEditors:XamMaskedEditor Width="100" Margin="5" IsReadOnly="True" EditModeStarting="mask_EditModeStarting"  VerticalAlignment="Top" Name="mask"  HorizontalAlignment="Left" PromptChar="" >
        <igEditors:XamMaskedEditor.Resources>
            <Style TargetType="{x:Type igEditors:CaretElement}">
                <Style.Triggers>
                    <DataTrigger Binding="{Binding  RelativeSource={RelativeSource Mode=FindAncestor, AncestorType={x:Type igEditors:XamMaskedEditor}}, Path=IsReadOnly}" Value="true">
                        <Setter Property="Background" Value="Transparent" />
                    </DataTrigger>
                </Style.Triggers>
            </Style>
        </igEditors:XamMaskedEditor.Resources>
    </igEditors:XamMaskedEditor>
    Please let me know if I can assist you further on the matter.
    Sincerely,
    Petar Monov
    Developer Support Engineer
    Infragistics Bulgaria
    www.infragistics.com/support
