65
xam map shows compile error
i tried a sample xam map application
but it showing compile error ("cannot create instance of coordinate system").
 xamlparse exception :- "The type initializer for 'Infragistics.Controls.Maps.CoordinateSystem' threw an exception."
this is my sample code.
 <igMap:XamMap x:Name="mapControl">
            <igMap:XamMap.Layers>
                <igMap:MapLayer x:Name="Indiana">
                    <igMap:MapLayer.Reader>
                        <igMap:ShapeFileReader Uri="ShapeFiles/Samara_region_adm_map" >
                            <!-- Specify coordinate system with input projection type.
           Settings for each attribute is obtained from the .txt Shapefile -->
                            <igMap:ShapeFileReader.CoordinateSystem> //ERROR<"cannot create instance of coordinate system">
                                <igMap:CoordinateSystem >
                                    <igMap:CoordinateSystem.Projection>
                                        <igMap:TransverseMercator >
                                        </igMap:TransverseMercator>
                                    </igMap:CoordinateSystem.Projection>
                                </igMap:CoordinateSystem>
                                <!--<igMap:CoordinateSystem UnitType="M" FalseEasting="500000">
                                        <igMap:TransverseMercator CentralMeridian="-87" LatitudeOrigin="0,0" />
                                </igMap:CoordinateSystem>-->
                            </igMap:ShapeFileReader.CoordinateSystem>
                        </igMap:ShapeFileReader>
                    </igMap:MapLayer.Reader>
                </igMap:MapLayer>
            </igMap:XamMap.Layers>
        </igMap:XamMap>
this is my reference "http://help.infragistics.com/Help/NetAdvantage/WPFDV/2010.2/CLR4.0/html/xamWebMap_Change_Map_Coordinate_System.html"
regards
balu
