I have this style from my XAMTEXTEDITORS
<Style TargetType="{x:Type igEditors:XamTextEditor}" > <Setter Property="Background" Value="{DynamicResource {x:Static SystemColors.WindowBrushKey}}" /> <Setter Property="BorderBrush" Value="Black" /> <Setter Property="BorderThickness" Value="1" /> <Setter Property="Padding" Value="2,2,2,2" /> <Setter Property="Margin" Value="{DynamicResource {x:Static igEditors:EditorsBrushKeys.TextEditorMarginKey}}" /> <Setter Property="SnapsToDevicePixels" Value="True"/> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type igEditors:XamTextEditor}"> <Border x:Name="MainBorder" CornerRadius="1" Background="{TemplateBinding Background}" BorderBrush="{TemplateBinding BorderBrush}" BorderThickness="{TemplateBinding BorderThickness}" SnapsToDevicePixels="{TemplateBinding SnapsToDevicePixels}" > <TextBlock x:Name="TextBlock" Margin="{TemplateBinding Padding}" Text="{TemplateBinding DisplayText}" TextWrapping="{TemplateBinding TextWrapping}" HorizontalAlignment="{TemplateBinding HorizontalContentAlignment}" VerticalAlignment="{TemplateBinding VerticalContentAlignment}" TextAlignment="{TemplateBinding TextAlignmentResolved}" /> </Border> </ControlTemplate> </Setter.Value> </Setter> <Setter Property="EditTemplate"> <Setter.Value> <ControlTemplate TargetType="{x:Type igEditors:XamTextEditor}"> <Border x:Name="MainBorder" Background="{TemplateBinding Background}" BorderBrush="{TemplateBinding BorderBrush}" BorderThickness="{TemplateBinding BorderThickness}" CornerRadius="5">
<TextBox Name="PART_FocusSite" Padding="{TemplateBinding Padding}" Text="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Text, Mode=TwoWay, UpdateSourceTrigger=PropertyChanged}" TextWrapping="{TemplateBinding TextWrapping}" HorizontalScrollBarVisibility="{TemplateBinding HorizontalScrollBarVisibility}" VerticalScrollBarVisibility="{TemplateBinding VerticalScrollBarVisibility}" HorizontalContentAlignment="{TemplateBinding HorizontalContentAlignment}" VerticalContentAlignment="{TemplateBinding VerticalContentAlignment}" TextAlignment="{TemplateBinding TextAlignmentResolved}" MaxLength="{Binding Path=ValueConstraint.MaxLength, Mode=TwoWay}" IsReadOnly="{TemplateBinding ReadOnly}" Background="Transparent" BorderBrush="Transparent" BorderThickness="0,0,0,0" Foreground="{TemplateBinding Foreground}" ContextMenu="{TemplateBinding ContextMenu}" SpellCheck.IsEnabled="{TemplateBinding SpellCheck.IsEnabled}" SpellCheck.SpellingReform="{TemplateBinding SpellCheck.SpellingReform}" /> </Border> <ControlTemplate.Triggers> <Trigger Property="IsInEditMode" Value="True"> <Setter Property="IsTabStop" Value="False" /> <Setter Property="Padding" Value="0,2,2,2"/> </Trigger> </ControlTemplate.Triggers> </ControlTemplate> </Setter.Value> </Setter> <Style.Triggers> <MultiTrigger> <MultiTrigger.Conditions> <Condition Property="IsEmbedded" Value="True"/> <Condition Property="IsInEditMode" Value="False"/> </MultiTrigger.Conditions> <Setter Property="Background" Value="{x:Null}"/> <Setter Property="BorderBrush" Value="{x:Null}"/> <Setter Property="Padding" Value="2,2,2,2"/> </MultiTrigger> <Trigger Property="IsEnabled" Value="False"> <Setter Property="BorderBrush" Value="{DynamicResource {x:Static SystemColors.InactiveBorderBrushKey}}"/> <Setter Property="Background" Value="{DynamicResource {x:Static SystemColors.WindowBrushKey}}" /> <Setter Property="Foreground" Value="{DynamicResource {x:Static SystemColors.GrayTextBrushKey}}" /> </Trigger> </Style.Triggers> </Style>
My problem is that I want change the editor maxlength at runtime because I have this data at runtime form Database.
I have tried with this code
vc.MaxLength = 25 (Data form Database)
Dim setter4 As New Setter(XamTextEditor.ValueConstraintProperty, vc)
XamDGFormasPago.Records.FieldLayout.Fields(
"COD").Settings.EditorType = GetType(XamTextEditor)
st3.TargetType =
st3.Setters.Add(setter4)
"COD").Settings.EditorStyle = st3
The problem is that my text editor maxlength is 25 but the editor doesn`t have rounded borders.
Can yo explain me how can I do it.
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post I can suggest you set the CornerRadius Property of the “MainBorder” Border that is in the Template to 5.
